For example battery?
你好,请问一下,这边是否支持在底座的边沿版新增一个纽扣电池,用来保存系统的时间?
如果可以的话,这边电源纽扣商品的链接地址有么??
Please refer to below RTC info in Nano module datasheet in DLC.
The following backup cells may be attached to the PMIC_BBAT pin:
Super Capacitor (gold cap, double layer electrolytic)
Standard capacitors (tantalum)
Rechargeable Lithium Manganese cells
The backup cells MUST provide a voltage in the range 2.5V to 3.5V. These is charged with a constant current (CC), constant
voltage (CV) charger that can be configured between 2.5V and 3.5V CV output and 50μA to 800μA CC.
