Can Alt-Link ECC be enabled on Jetson AGX Thor T4000?
I noticed that Alt-Link ECC is available on Jetson AGX Thor T5000.
Is Alt-Link ECC supported on Jetson AGX Thor T4000, or is it limited to T5000 hardware?
If available, can it be enabled through software or configuration changes?
Also, if possible, could you clarify whether Alt-Link ECC support exists on T3000 and T2000 modules as well?
Thank you.
Thanks for filing the ticket.
I am internally checking to confirm the Alt-link ECC support per sku.
I will get back to this ticket once I get confirmed.
Yes, Alt-Link ECC requires dedicated pins on DDR.
DDR on T4000 does not support Alt-Link ECC by HW.
It is still TBD.
Thank you for the inaformation.
