I need to do inference on the data that is expected to be streaming over the ethernet on to the AGX. The network is a custom network that is supposed to do inference on the data over the ethernet.
Any help is appreciated.
What kind of application are you using now? We have gstreamer and deepstream that may achieve your goal.
This is something new that I am trying out using AGX. Any sample code is available for gstreamer/deepstream?
After installation, you will see samples in
/opt/nvidia/deepstream/deepstream-5.1/
May try to run this config file through deepstream-app:
/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app$ deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
We have implementation about RTSP sink. Please refer to document to enable it and give it a try:
DeepStream Reference Application - deepstream-app — DeepStream 6.1.1 Release documentation
Thanks will try out this!
