- Copyright 1993-2014 NVIDIA Corporation. All rights reserved.
- Please refer to the NVIDIA end user license agreement (EULA) associated
- with this source code for terms and conditions that govern your use of
- this software. Any use, reproduction, disclosure, or distribution of
- this software and related documentation outside the terms of the EULA
- is strictly prohibited.
- This sample demonstrates two adaptive image denoising technqiues:
- KNN and NLM, based on computation of both geometric and color distance
- between texels. While both techniques are already implemented in the
- DirectX SDK using shaders, massively speeded up variation
- of the latter techique, taking advantage of shared memory, is implemented
- in addition to DirectX counterparts.
- See supplied whitepaper for more explanations.
// OpenGL Graphics includes
#include <GL/glew.h>
#if defined(APPLE) || defined(MACOSX)
#include <GLUT/glut.h>
#else
#include <GL/freeglut.h>
#endif
// CUDA utilities and system includes
#include <cuda_runtime.h>
#include <cuda_gl_interop.h>
// Includes
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include “imageDenoising.h”
// includes, project
#include <helper_functions.h> // includes for helper utility functions
#include <helper_cuda.h> // includes for cuda error checking and initialization
const char *sSDKsample = “CUDA ImageDenoising”;
const char *filterMode =
“Passthrough”,
“KNN method”,
“NLM method”,
“Quick NLM(NLM2) method”,
NULL
// Define the files that are to be save and the reference images for validation
const char *sOriginal =
“image_passthru.ppm”,
“image_knn.ppm”,
“image_nlm.ppm”,
“image_nlm2.ppm”,
NULL
const char *sReference =
“ref_passthru.ppm”,
“ref_knn.ppm”,
“ref_nlm.ppm”,
“ref_nlm2.ppm”,
NULL
// Global data handlers and parameters
//OpenGL PBO and texture “names”
GLuint gl_PBO, gl_Tex;
struct cudaGraphicsResource *cuda_pbo_resource; // handles OpenGL-CUDA exchange
//Source image on the host side
uchar4 *h_Src;
int imageW, imageH;
GLuint shader;
// Main program
int g_Kernel = 0;
bool g_FPS = false;
bool g_Diag = false;
StopWatchInterface *timer = NULL;
//Algorithms global parameters
const float noiseStep = 0.025f;
const float lerpStep = 0.025f;
static float knnNoise = 0.32f;
static float nlmNoise = 1.45f;
static float lerpC = 0.2f;
const int frameN = 24;
int frameCounter = 0;
#define BUFFER_DATA(i) ((char *)0 + i)
// Auto-Verification Code
const int frameCheckNumber = 4;
int fpsCount = 0; // FPS count for averaging
int fpsLimit = 1; // FPS limit for sampling
unsigned int frameCount = 0;
unsigned int g_TotalErrors = 0;
int *pArgc = NULL;
char **pArgv = NULL;
#define MAX_EPSILON_ERROR 5
#define REFRESH_DELAY 10 //ms
void computeFPS()
frameCount++;
fpsCount++;
if (fpsCount == fpsLimit)
char fps[256];
float ifps = 1.f / (sdkGetAverageTimerValue(&timer) / 1000.f);
sprintf(fps, "<%s>: %3.1f fps", filterMode[g_Kernel], ifps);
glutSetWindowTitle(fps);
fpsCount = 0;
//fpsLimit = (int)MAX(ifps, 1.f);
sdkResetTimer(&timer);
void runImageFilters(TColor *d_dst)
sdkStartTimer(&timer);
switch (g_Kernel)
case 0:
cuda_Copy(d_dst, imageW, imageH);
break;
case 1:
if (!g_Diag)
cuda_KNN(d_dst, imageW, imageH, 1.0f / (knnNoise * knnNoise), lerpC);
else
cuda_KNNdiag(d_dst, imageW, imageH, 1.0f / (knnNoise * knnNoise), lerpC);
break;
case 2:
if (!g_Diag)
cuda_NLM(d_dst, imageW, imageH, 1.0f / (nlmNoise * nlmNoise), lerpC);
else
cuda_NLMdiag(d_dst, imageW, imageH, 1.0f / (nlmNoise * nlmNoise), lerpC);
break;
case 3:
if (!g_Diag)
cuda_NLM2(d_dst, imageW, imageH, 1.0f / (nlmNoise * nlmNoise), lerpC);
else
cuda_NLM2diag(d_dst, imageW, imageH, 1.0f / (nlmNoise * nlmNoise), lerpC);
break;
printf("TimeTaken for execution: %f \n seconds", sdkGetTimerValue(&timer) * 0.001);
sdkStopTimer(&timer);
getLastCudaError("Filtering kernel execution failed.\n");
void displayFunc(void)
TColor *d_dst = NULL;
size_t num_bytes;
if (frameCounter++ == 0)
// DEPRECATED: checkCudaErrors(cudaGLMapBufferObject((void**)&d_dst, gl_PBO));
checkCudaErrors(cudaGraphicsMapResources(1, &cuda_pbo_resource, 0));
getLastCudaError("cudaGraphicsMapResources failed");
checkCudaErrors(cudaGraphicsResourceGetMappedPointer((void **)&d_dst, &num_bytes, cuda_pbo_resource));
getLastCudaError("cudaGraphicsResourceGetMappedPointer failed");
checkCudaErrors(CUDA_Bind2TextureArray());
runImageFilters(d_dst);
checkCudaErrors(CUDA_UnbindTexture());
// DEPRECATED: checkCudaErrors(cudaGLUnmapBufferObject(gl_PBO));
checkCudaErrors(cudaGraphicsUnmapResources(1, &cuda_pbo_resource, 0));
// Common display code path
glClear(GL_COLOR_BUFFER_BIT);
glTexSubImage2D(GL_TEXTURE_2D, 0, 0, 0, imageW, imageH, GL_RGBA, GL_UNSIGNED_BYTE, BUFFER_DATA(0));
glBegin(GL_TRIANGLES);
glTexCoord2f(0, 0);
glVertex2f(-1, -1);
glTexCoord2f(2, 0);
glVertex2f(+3, -1);
glTexCoord2f(0, 2);
glVertex2f(-1, +3);
glEnd();
glFinish();
if (frameCounter == frameN)
frameCounter = 0;
if (g_FPS)
printf("FPS: %3.1f\n", frameN / (sdkGetTimerValue(&timer) * 0.001));
g_FPS = false;
glutSwapBuffers();
computeFPS();
void timerEvent(int value)
glutPostRedisplay();
glutTimerFunc(REFRESH_DELAY, timerEvent, 0);
void shutDown(unsigned char k, int /x/, int /y/)
switch (k)
case ‘\033’:
case ‘q’:
case ‘Q’:
printf(“Shutting down…\n”);
sdkDeleteTimer(&timer);
checkCudaErrors(CUDA_FreeArray());
free(h_Src);
exit(EXIT_SUCCESS);
break;
case '1':
printf("Passthrough.\n");
g_Kernel = 0;
break;
case '2':
printf("KNN method \n");
g_Kernel = 1;
break;
case '3':
printf("NLM method\n");
g_Kernel = 2;
break;
case '4':
printf("Quick NLM(NLM2) method\n");
g_Kernel = 3;
break;
case '*':
printf(g_Diag ? "LERP highlighting mode.\n" : "Normal mode.\n");
g_Diag = !g_Diag;
break;
case 'n':
printf("Decrease noise level.\n");
knnNoise -= noiseStep;
nlmNoise -= noiseStep;
break;
case 'N':
printf("Increase noise level.\n");
knnNoise += noiseStep;
nlmNoise += noiseStep;
break;
case 'l':
printf("Decrease LERP quotent.\n");
lerpC = MAX(lerpC - lerpStep, 0.0f);
break;
case 'L':
printf("Increase LERP quotent.\n");
lerpC = MIN(lerpC + lerpStep, 1.0f);
break;
case 'f' :
case 'F':
g_FPS = true;
break;
case '?':
printf("lerpC = %5.5f\n", lerpC);
printf("knnNoise = %5.5f\n", knnNoise);
printf("nlmNoise = %5.5f\n", nlmNoise);
break;
int initGL(int *argc, char **argv)
printf(“Initializing GLUT…\n”);
glutInit(argc, argv);
glutInitDisplayMode(GLUT_RGBA | GLUT_DOUBLE);
glutInitWindowSize(imageW, imageH);
glutInitWindowPosition(512 - imageW / 2, 384 - imageH / 2);
glutCreateWindow(argv[0]);
printf(“OpenGL window created.\n”);
glewInit();
printf("Loading extensions: %s\n", glewGetErrorString(glewInit()));
if (!glewIsSupported("GL_VERSION_1_5 GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object"))
fprintf(stderr, "Error: failed to get minimal extensions for demo\n");
fprintf(stderr, "This sample requires:\n");
fprintf(stderr, " OpenGL version 1.5\n");
fprintf(stderr, " GL_ARB_vertex_buffer_object\n");
fprintf(stderr, " GL_ARB_pixel_buffer_object\n");
fflush(stderr);
return false;
return 0;
// shader for displaying floating-point texture
static const char *shader_code =
“!!ARBfp1.0\n”
“TEX result.color, fragment.texcoord, texture[0], 2D; \n”
“END”;
GLuint compileASMShader(GLenum program_type, const char *code)
GLuint program_id;
glGenProgramsARB(1, &program_id);
glBindProgramARB(program_type, program_id);
glProgramStringARB(program_type, GL_PROGRAM_FORMAT_ASCII_ARB, (GLsizei) strlen(code), (GLubyte *) code);
GLint error_pos;
glGetIntegerv(GL_PROGRAM_ERROR_POSITION_ARB, &error_pos);
if (error_pos != -1)
const GLubyte *error_string;
error_string = glGetString(GL_PROGRAM_ERROR_STRING_ARB);
fprintf(stderr, "Program error at position: %d\n%s\n", (int)error_pos, error_string);
return 0;
return program_id;
void initOpenGLBuffers()
printf(“Creating GL texture…\n”);
glEnable(GL_TEXTURE_2D);
glGenTextures(1, &gl_Tex);
glBindTexture(GL_TEXTURE_2D, gl_Tex);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_CLAMP);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA8, imageW, imageH, 0, GL_RGBA, GL_UNSIGNED_BYTE, h_Src);
printf(“Texture created.\n”);
printf("Creating PBO...\n");
glGenBuffers(1, &gl_PBO);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER_ARB, gl_PBO);
glBufferData(GL_PIXEL_UNPACK_BUFFER_ARB, imageW * imageH * 4, h_Src, GL_STREAM_COPY);
//While a PBO is registered to CUDA, it can't be used
//as the destination for OpenGL drawing calls.
//But in our particular case OpenGL is only used
//to display the content of the PBO, specified by CUDA kernels,
//so we need to register/unregister it only once.
// DEPRECATED: checkCudaErrors(cudaGLRegisterBufferObject(gl_PBO) );
checkCudaErrors(cudaGraphicsGLRegisterBuffer(&cuda_pbo_resource, gl_PBO,
cudaGraphicsMapFlagsWriteDiscard));
GLenum gl_error = glGetError();
if (gl_error != GL_NO_ERROR)
#if defined(WIN32) || defined(_WIN32) || defined(WIN64) || defined(_WIN64)
char tmpStr[512];
// NOTE: "%s(%i) : " allows Visual Studio to directly jump to the file at the right line
// when the user double clicks on the error line in the Output pane. Like any compile error.
sprintf_s(tmpStr, 255, “\n%s(%i) : GL Error : %s\n\n”, FILE, LINE, gluErrorString(gl_error));
OutputDebugString(tmpStr);
#endif
fprintf(stderr, “GL Error in file ‘%s’ in line %d :\n”, FILE, LINE);
fprintf(stderr, “%s\n”, gluErrorString(gl_error));
exit(EXIT_FAILURE);
printf("PBO created.\n");
// load shader program
shader = compileASMShader(GL_FRAGMENT_PROGRAM_ARB, shader_code);
void cleanup()
glDeleteProgramsARB(1, &shader);
void runAutoTest(int argc, char **argv, const char *filename, int kernel_param)
printf(“[%s] - (automated testing w/ readback)\n”, sSDKsample);
int devID = findCudaDevice(argc, (const char **)argv);
// First load the image, so we know what the size of the image (imageW and imageH)
printf("Allocating host and CUDA memory and loading image file...\n");
const char *image_path = sdkFindFilePath("portrait_noise.bmp", argv[0]);
if (image_path == NULL)
printf("imageDenoisingGL was unable to find and load image file <portrait_noise.bmp>.\nExiting...\n");
exit(EXIT_FAILURE);
LoadBMPFile(&h_Src, &imageW, &imageH, image_path);
printf("Data init done.\n");
checkCudaErrors(CUDA_MallocArray(&h_Src, imageW, imageH));
unsigned char *h_dst = NULL;
checkCudaErrors(cudaMalloc((void **)&d_dst, imageW*imageH*sizeof(TColor)));
h_dst = (unsigned char *)malloc(imageH*imageW*4);
g_Kernel = kernel_param;
printf("[AutoTest]: %s <%s>\n", sSDKsample, filterMode[g_Kernel]);
checkCudaErrors(cudaDeviceSynchronize());
checkCudaErrors(cudaMemcpy(h_dst, d_dst, imageW*imageH*sizeof(TColor), cudaMemcpyDeviceToHost));
sdkSavePPM4ub(filename, h_dst, imageW, imageH);
free(h_Src);
checkCudaErrors(cudaFree(d_dst));
free(h_dst);
printf("\n[%s] -> Kernel %d, Saved: %s\n", sSDKsample, kernel_param, filename);
// cudaDeviceReset causes the driver to clean up all state. While
// not mandatory in normal operation, it is good practice. It is also
// needed to ensure correct operation when the application is being
// profiled. Calling cudaDeviceReset causes all profile data to be
// flushed before the application exits
cudaDeviceReset();
exit(g_TotalErrors == 0 ? EXIT_SUCCESS : EXIT_FAILURE);
int main(int argc, char **argv)
char *dump_file = NULL;
pArgc = &argc;
pArgv = argv;
printf("%s Starting...\n\n", sSDKsample);
if (checkCmdLineFlag(argc, (const char **)argv, "file"))
getCmdLineArgumentString(argc, (const char **)argv,
"file", (char **) &dump_file);
int kernel = 1;
if (checkCmdLineFlag(argc, (const char **)argv, "kernel"))
kernel = getCmdLineArgumentInt(argc, (const char **)argv, "kernel");
runAutoTest(argc, argv, dump_file, kernel);
else
printf("[%s]\n", sSDKsample);
// use command-line specified CUDA device, otherwise use device with highest Gflops/s
if (checkCmdLineFlag(argc, (const char **)argv, "device"))
printf("[%s]\n", argv[0]);
printf(" Does not explicitly support -device=n in OpenGL mode\n");
printf(" To use -device=n, the sample must be running w/o OpenGL\n\n");
printf(" > %s -device=n -qatest\n", argv[0]);
printf("exiting...\n");
exit(EXIT_SUCCESS);
exit(EXIT_FAILURE);
// First initialize OpenGL context, so we can properly set the GL for CUDA.
// This is necessary in order to achieve optimal performance with OpenGL/CUDA interop.
initGL(&argc, argv);
cudaGLSetGLDevice(gpuGetMaxGflopsDeviceId());
initOpenGLBuffers();
printf("Starting GLUT main loop...\n");
printf("Press [1] to view noisy image\n");
printf("Press [2] to view image restored with knn filter\n");
printf("Press [3] to view image restored with nlm filter\n");
printf("Press [4] to view image restored with modified nlm filter\n");
printf("Press [*] to view smooth/edgy areas [RED/BLUE] Ct's when a filter is active\n");
printf("Press [f] to print frame rate\n");
printf("Press [?] to print Noise and Lerp Ct's\n");
printf("Press [q] to exit\n");
glutDisplayFunc(displayFunc);
glutKeyboardFunc(shutDown);
sdkCreateTimer(&timer);
glutTimerFunc(REFRESH_DELAY, timerEvent,10000000);
glutMainLoop();
cudaDeviceReset();
exit(EXIT_SUCCESS);
