Can anyone suggest a good Python IDE for Jetson Nano
Can anyone suggest a good python IDE to run on the Jetson Nano.
I was able to install pycharm according to the instructions on these forums here:
https://devtalk.nvidia.com/default/topic/1049638/nsight-eclipse-edition/looking-for-python-ide-to-run-on-jetson-nano/
However, the problem is that although pycharm installs, runs, and projects can be created, it fails when you try and add any libraries. Error says that package can not be installed and try using pip instead.
Is there a way to fix this, or is there a suggestion for a good python editor to run on Jetson Nano.
Thank you.
Try Theia-IDE or VS Code
