As you know, the sd card memory isn’t optimal solution for industrial project, because after a while due to I/O of sd cards that cause a problem.
I want to know, Is it possible to use ssd memory instead of sd card and flash the img file into ssd memory?
Yes, it is possible. We have a page here.
@WayneWWW, Thanks,
I think that page is tested for jetson tx2, Is it possible to run same instructions for jetson xavier nx and nano?
It would work for nx and nano too.
