I would like to confirm whether it is supported and electrically/mechanically feasible to connect PCIe/NVMe SSDs to the PCIe auxiliary / extension interface of a NVIDIA BlueField-3 B3220 P-Series DPU, specifically model: BlueField-3 B3220 P-Series (900-9D3B6-00CV)
According to the BlueField-3 documentation, the PCIe Auxiliary Card Kit appears to expose Downstream Port capability:
https://docs.nvidia.com/networking/display/bf3dpu/pcie-auxiliary-card-kit
On my DPU, I can successfully configure PCIe bifurcation so that the main gold-finger interface remains x16 and the auxiliary/extension side is split into four x4 links:
sudo mlxconfig -d /dev/mst/mt41692_pciconf0 s \
PCI_BUS00_HIERARCHY_TYPE=0 PCI_BUS00_WIDTH=5 PCI_BUS00_SPEED=4 \
PCI_BUS10_HIERARCHY_TYPE=2 PCI_BUS10_WIDTH=3 PCI_BUS10_SPEED=4 \
PCI_BUS12_HIERARCHY_TYPE=2 PCI_BUS12_WIDTH=3 PCI_BUS12_SPEED=4 \
PCI_BUS14_HIERARCHY_TYPE=2 PCI_BUS14_WIDTH=3 PCI_BUS14_SPEED=4 \
PCI_BUS16_HIERARCHY_TYPE=2 PCI_BUS16_WIDTH=3 PCI_BUS16_SPEED=4
Based on the PCIe Auxiliary Card Mechanical Drawings and Dimensions, it seems that the auxiliary connector can be converted to a PCIe x16 edge connector using the PCIe Auxiliary Card Kit.
My questions are:
Is it officially supported to connect PCIe/NVMe SSDs behind the BlueField-3 auxiliary interface when it is configured as downstream ports? Is there an NVIDIA-recommended adapter, carrier board, backplane, or PCIe switch board for converting the auxiliary interface to a standard PCIe x16 slot?
If the auxiliary card exposes a PCIe x16 edge connector, can a passive female-to-female PCIe adapter/riser be used to convert it into a PCIe x16 slot, so that an SSD adapter card can be inserted?
The intended topology is:
BlueField-3 auxiliary connector | PCIe Auxiliary Card Kit | PCIe x16 edge connector | passive female-to-female PCIe adapter / riser | PCIe x16 slot | NVMe SSD adapter card / M.2 adapter / PCIe switch card | NVMe SSDs -
If this configuration is supported, should the SSDs be visible to the BlueField Arm side as local PCIe/NVMe devices when the auxiliary interface is configured as downstream ports?
The goal is to attach local PCIe/NVMe SSDs behind the BlueField-3 DPU, preferably visible to the BlueField Arm cores, for a storage/JBOF-style prototype.
Any guidance on the supported topology, required adapter hardware, and limitations would be appreciated.
