CAN bus does not work properly with 1 Mbit/s baudrate
We have the problem that the CAN bus does not work properly with 1 Mbit/s baud rate. With 500 Kbit/s everything works fine.
Our test setup:
PCAN-USB - Drive PX2, Tegra A, CAN E
sudo ip link set can0 type can bitrate 1000000
sudo ip link set can0 up
nvidia@tegra-ubuntu:~$ dmesg | grep mttcan
[ 8.387595] net can0: mttcan device registered (regs=ffffff800abfb000, irq=370)
[ 8.444226] net can1: mttcan device registered (regs=ffffff800af1e000, irq=371)
[ 146.981276] mttcan c310000.mttcan can0: Bitrate set
[ 163.220042] mttcan_controller_config: ctrlmode 0
[ 163.220071] mttcan c310000.mttcan can0: Bitrate set
[ 208.331394] mttcan c310000.mttcan can0: entered error warning state
[ 208.331952] mttcan c310000.mttcan can0: entered error passive state
nvidia@tegra-ubuntu:~$ ip -details -statistics link show can0
6: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
link/can promiscuity 0
can state ERROR-PASSIVE (berr-counter tx 0 rx 121) restart-ms 0
bitrate 1000000 sample-point 0.750
tq 25 prop-seg 14 phase-seg1 15 phase-seg2 10 sjw 1
mttcan: tseg1 2…255 tseg2 0…127 sjw 1…127 brp 1…511 brp-inc 1
mttcan: dtseg1 1…31 dtseg2 0…15 dsjw 1…15 dbrp 1…15 dbrp-inc 1
clock 40000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 1 1 0
RX: bytes packets errors dropped overrun mcast
16 2 0 2 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
Dear High-OctaneMotorsports,
Could you please refer to below link and comment for your topic? Thanks.
“CAN controller always settings 500kbps as default baudrate,
please modify the Can_17_MCanP_PBCfg.c manually, if you would like to change the default baudrate settings.
paste the function as below for your reference, thanks”
https://devtalk.nvidia.com/default/topic/1036761/drive-hardware/how-to-save-aurix-configuration-/post/5280902/#5280902
Is the CAN E connector not directly connected to Tegra A?
Could you please refer to below info for your topic?
https://devtalk.nvidia.com/default/topic/1048869/drive-hardware/what-is-socket-can-port-on-tegra/post/5323787/#5323787
Harness cable
  • can-5 -------> can0 on Tegra A
  • can-6 -------> can1 on Tegra B
  • can-1 -------> channel A on Aurix
  • can-2 -------> channel B on Aurix
  • can-3 -------> channel C on Aurix
  • can-4 -------> channel D on Aurix
The fifth CAN connector is labeled CAN E on my Nvidia wiring harness and is directly connected to Tegra A. I can’t understand what your answer regarding the Aurix microcontroller has to do with my problem.
Sorry for confusing you.
We had updated the harness label the numbering to match the letters as below.
CAN A = CAN 1,
CAN B = CAN 2,
CAN C = CAN 3,
CAN D = CAN 4,
CAN E = CAN 5,
CAN F = CAN 6
Could you please refer to Table2 in DRIVE PX 2 AutoChauffeur Mechanical and Installation Guide (PDF) in https://developer.nvidia.com/drive/documentation?
