I am using a CAN library for a specific device that looks for the CAN device in /dev
. After following these steps on setting up the CAN controller the CAN network shows up when I use dmesg
and ifconfig
, but I still do not see any CAN devices in /dev
. Are there steps that are missing in the response to that post on how to setup the CAN device so that it appears in /dev
Hi nick,
CAN driver does not create a character device node /dev/ for can.
Why do you need /dev/ to use can exposed to network?
You can directly use can0 ,can1 nodes from can-utils as mentioned in the link you shared.
Thanks,
Shubhi
Shubhi,
It seems that the CAN library from the company whose device we are trying to communicate with uses file reading/writing to the device file. So their library as is will not work if there is no device file for the CAN bus. I could rework their software to use SocketCAN, but I would like to avoid this if possible to save development time. If the CAN driver does not currently create a character device node, then it seems that I will need to move forward with using SocketCAN.
Thanks,
Nick
