I tried to connect Drive PX2 CAN bus with my host PC PCAN. I could send message from PX2 and my host PC successfully received it. However, when I send CAN message from my host PC, the PX2 did not receive at all. Both CAN0 (Tegra A, using Can-5 cable) and CAN1 (Tegra B, using Can-6 cable) behave the same. To test, I used can-utils CANDUMP for receiving and CANSEND to send the message. I also set the ip link can0 and can1 up prior to using the CAN bus.
Here are the devices’ details by executing command
ip -details -statistics link show can0
- Host PC (PCAN)
6: can 0: <NOARP, UP, LOWER_UP> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/can promiscuity 0
can <TRIPLE-SAMPLING> state ERROR-ACTIVE restart-ms 0
bitrate 500000 sample-point 0.875
tq 125 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
pcan: tseg1 1..16 tseg2 1..8 sjw 1..4 brp 1..64 brp-inc 1
clock 8000000
- Drive PX2 (let it be CAN0, Tegra A using Can-5 cable)
7: can0: <NOARP, UP, LOWER_UP, ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 1000
can state ERROR-ACTIVE (berr-counter tx 0 rx 1) restart-ms 0
mttcan: tseg1 2..255 tseg2 0..127 sjw 1..127 brp 1..511 brp-inc 1
mttcan: dtseg1 1..31 dtseg2 0..15 dsjw 1..15 dbrp 1..15 dbrp-inc 1
clock 40000000
Drive PX2 CAN bus could not receive any messages from host PC PCAN. How could I fix this problem?
