Hi!
I’m trying to communicate by CAN on Jetson TX2 and after MANY tests… nothing.
I followed this procedure to enable the CAN network: https://translate.google.com/translate?hl=en&sl=ja&tl=en&u=http%3A%2F%2Fdocs.fabo.io%2Fjetson%2FJetPack3.1%2Fsetup%2Fcan.html&sandbox=1
The last test I did was to directly connect CAN0 pins to CAN1 (pins 5, 7 and 15, 17 from J26 connector), with no transceiver. Errors (by dmesg):
[ 218.626223] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 218.631829] mttcan c310000.mttcan can0: IR 0x8010000 PSR 0x71d
[ 218.637715] mttcan c320000.mttcan can1: Stuff Error Detected
[ 218.643413] mttcan c320000.mttcan can1: IR 0x8010000 PSR 0x711
[ 218.649750] mttcan c310000.mttcan can0: entered error warning state
[ 218.656049] mttcan c310000.mttcan can0: entered error passive state
[ 218.662334] mttcan c310000.mttcan can0: entered bus off state
[ 218.668096] mttcan c310000.mttcan can0: Bit0 Error Detected
[ 218.673679] mttcan c310000.mttcan can0: IR 0xb800000 PSR 0x7e5
[ 218.679634] mttcan c320000.mttcan can1: entered error warning state
[ 218.685927] mttcan c320000.mttcan can1: entered error passive state
Commands :
$ cansend can0 123#abcdabcd
$ cansend can0 01a#11223344AABBCCDD
$ candump can1 (on other terminal)
So I think the problem is not my transceiver (SN65HVD230). Any ideia?
Mauricio de O. Pena
hello mauricio65nif,
may I have more details about your environments, for example, which Jetpack release you’re working with.
thanks
Hi @JerryChang .
JetPack 4.2. Ubuntu 18.04.2 LTS
Same error even if I don’t connect anything to the J26 pins. :-/
Different errors when I set different speeds:
250000 or 125000
[ 661.287363] mttcan c310000.mttcan can0: entered error warning state
[ 661.293704] mttcan c320000.mttcan can1: entered error warning state
[ 661.300028] mttcan c320000.mttcan can1: entered error passive state
[ 661.306373] mttcan c310000.mttcan can0: entered error passive state
[ 661.312677] mttcan c310000.mttcan can0: entered bus off state
could you please configure the CAN interface settings,
for example,
$ ifconfig can0 down
$ ip link set can0 type can bitrate 500000 restart-ms 1000
suggest you also refer to Topic 1037624 for similar discussion.
thanks
JerryChang:
for example,
thanks
Same error here.
[ 386.723501] mttcan c310000.mttcan can0: entered error warning state
[ 386.729857] mttcan c320000.mttcan can1: entered error warning state
[ 386.736178] mttcan c320000.mttcan can1: entered error passive state
[ 386.742601] mttcan c310000.mttcan can0: entered error passive state
[ 386.748921] mttcan c310000.mttcan can0: entered bus off state
[ 387.776468] mttcan c310000.mttcan can0: wait for bus off seq
[ 387.788732] mttcan c310000.mttcan can0: entered error warning state
[ 387.795122] mttcan c310000.mttcan can0: entered error passive state
[ 387.801492] mttcan c310000.mttcan can0: entered bus off state
[ 387.807343] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 388.832121] mttcan c310000.mttcan can0: wait for bus off seq
[ 388.844232] mttcan c310000.mttcan can0: entered error warning state
[ 388.850542] mttcan c310000.mttcan can0: entered error passive state
[ 388.856860] mttcan c310000.mttcan can0: entered bus off state
[ 389.887671] mttcan c310000.mttcan can0: wait for bus off seq
[ 389.899749] mttcan c310000.mttcan can0: entered error warning state
[ 389.906057] mttcan c310000.mttcan can0: entered error passive state
[ 389.912375] mttcan c310000.mttcan can0: entered bus off state
[ 390.943319] mttcan c310000.mttcan can0: wait for bus off seq
[ 390.955459] mttcan c310000.mttcan can0: entered error warning state
[ 390.961800] mttcan c310000.mttcan can0: entered error passive state
[ 390.968226] mttcan c310000.mttcan can0: entered bus off state
shgarg
August 6, 2019, 6:19am
#8
Hi Mauricio,
Since there is no transceiver on CAN0 & CAN1, CAN BUS is not formed, no transceiver so no message transfer.
You cannot communicate from Jetson-TX2 CAN without connecting external transceiver. TX2 CAN does not have any internal transceiver connected, it has given only controller support.
Thanks,
Shubhi
Hi Mauricio,
Hi Shubhi. I made this direct link because of a suggestion I read here in the Forum. I’ll try with the transceivers, again, tomorrow. Thanks!
New test, now with the transceiver and connected on a bus made with an Arduino + transceiver. The Arduino is sending 1 message / second:
$ sudo modprobe can
[ 44.665154] can: controller area network core (rev 20120528 abi 9)
[ 44.666132] NET: Registered protocol family 29
$ sudo modprobe can_raw
[ 82.161878] can: raw protocol (rev 20120528)
$ sudo modprobe mttcan
[ 128.026684] CAN device driver interface
[ 128.032788] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
[ 128.032960] Release 3.2.0 from 19.12.2014
[ 128.033471] net can0: mttcan device registered (regs=ffffff800ba1a000, irq=387)
[ 128.035221] Message RAM Configuration
| base addr |0x0c322000|
[ 128.035393] Release 3.2.0 from 19.12.2014
[ 128.035903] net can1: mttcan device registered (regs=ffffff800ba3c000, irq=388)
$ sudo ip link set can0 type can bitrate 500000 restart-ms 1000
[ 188.817380] mttcan c310000.mttcan can0: Bitrate set
$ sudo ip link set up can0
[ 208.681242] mttcan c310000.mttcan can0: entered error warning state
[ 208.687755] mttcan c310000.mttcan can0: entered error passive state
$ ifconfig
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 2 bytes 16 (16.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 131
$ candump can0
Shows nothing. :-/
Any ideia?
Mauricio
Test #2: now my Arduino just receives the data. Same modprobe commands, then:
$ sudo ip link set can0 type can bitrate 500000 dbitrate 2000000 berr-reporting on fd on
[ 150.092381] mttcan c310000.mttcan can0: Bitrate set
($dmesg shows nothing)
[ 185.704275] mttcan_controller_config: ctrlmode 30
[ 185.704309] mttcan c310000.mttcan can0: Bitrate set
[ 222.126073] mttcan c310000.mttcan can0: Acknowledgement Error Detected
[ 222.132634] mttcan c310000.mttcan can0: IR 0x8010000 PSR 0x71b
[ 222.138641] mttcan c310000.mttcan can0: entered error warning state
[ 222.144968] mttcan c310000.mttcan can0: entered error passive state
[ 222.151243] mttcan c310000.mttcan can0: Acknowledgement Error Detected
[ 222.157777] mttcan c310000.mttcan can0: IR 0x9800000 PSR 0x77b
[ 222.163682] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.169413] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x779
[ 222.175457] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.181165] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x779
[ 222.187069] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.192745] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x779
[ 222.198675] mttcan c310000.mttcan can0: Acknowledgement Error Detected
[ 222.205277] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x77b
[ 222.211266] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.216987] mttcan c310000.mttcan can0: IR 0x8000000 PSR 0x771
[ 222.223008] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.228907] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.234676] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.240484] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.246329] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.252074] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.257842] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.263602] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.269340] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.275111] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.280875] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.286674] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.292371] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.298064] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.303762] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.309800] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.315761] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.321715] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.327524] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.333357] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.339189] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.344894] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.350592] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.356339] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.362496] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.368839] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.374533] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.380230] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.385918] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.391609] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.397350] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.403039] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.408734] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.414555] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.420364] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.426257] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.432162] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.437985] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.444029] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.449739] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.455445] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.461139] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.466822] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.472554] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.491062] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.496802] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.502668] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.508918] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.514961] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.521765] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.528055] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.533850] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.539612] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.545392] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.551155] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.556856] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.562544] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.568232] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.573967] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.579652] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.585341] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.591032] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.596715] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.602507] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.608482] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.614454] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.620319] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.626097] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.632040] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.638132] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.644264] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.650276] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.656367] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.662204] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.667911] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.673604] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.679289] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.684971] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.691005] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.696943] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.702894] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.708714] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.714482] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.720199] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.725895] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.731587] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.737638] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.743569] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.749558] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.755403] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.761190] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.766900] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.772586] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.778368] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.784347] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.790301] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.796118] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.801897] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.807592] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.813280] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.818962] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.824645] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.830325] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.836067] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.841880] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.848152] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.854240] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.860174] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.866047] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.871749] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.877499] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.883228] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.888916] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.894967] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.901736] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.908428] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.914378] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.920293] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.925996] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.931741] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.937498] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.943547] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.949253] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.954955] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.960655] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.966394] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.972128] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.977833] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.983527] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.989213] mttcan c310000.mttcan can0: Stuff Error Detected
[ 222.994901] mttcan c310000.mttcan can0: Bit1 Error Detected
[ 223.000526] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.006349] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.012198] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.018075] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.024113] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.029848] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.035551] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.041292] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.047031] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.052728] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.058600] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.064662] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.070396] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.076114] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.081876] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.087580] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.093887] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.099957] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.105673] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.111778] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.117664] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.123623] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.129979] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.135789] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.141490] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.147595] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.153416] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.159463] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.165761] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.173373] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.179106] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.184843] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.190580] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.196413] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.202286] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.208174] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.214021] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.219751] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.225439] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.231158] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.237109] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.242810] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.248743] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.254828] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.260815] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.267087] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.273206] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.278995] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.284703] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.290400] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.296085] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.301956] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.307909] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.313888] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.319709] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.325741] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.331449] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.337147] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.342842] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.348557] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.354339] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.360183] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.366143] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.372133] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.377939] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.383958] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.389660] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.395357] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.401395] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.407363] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.413307] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.419173] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.425222] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.430926] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.436619] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.442311] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.447994] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.453674] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.459407] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.465097] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.470787] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.476478] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.482350] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.488304] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.494549] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.500438] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.506212] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.511961] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.517711] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.523765] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.529544] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.535343] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.541045] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.546736] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.552429] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.558216] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.564365] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.570323] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.576227] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.582266] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.587967] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.593664] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.599354] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.605092] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.610781] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.616469] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.622543] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.628692] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.634651] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.640490] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.646310] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.652005] mttcan c310000.mttcan can0: Stuff Error Detected
[ 223.657709] mttcan c310000.mttcan can0: entered bus off state
[ 223.663461] mttcan c310000.mttcan can0: Bit1 Error Detected
shgarg
November 18, 2019, 5:53am
#12
Hi mauricio,
I just replied to your other post. I guess you are facing the same issue in this post.
Can you look at it and let me know your results.
https://devtalk.nvidia.com/default/topic/1052755/jetson-tx2/step-by-step-tutorial-about-how-to-set-can-bus-in-jetson-tx2/post/5344406/#5344406
