CAN communication on Xavier
I followed the below link, pasted the code into ROS, and tried to run the code in ROS. But I ran into this problem: dwSAL_createSensor(&canSensor, params, hal) != DW_SUCCESS. I checked the value of dwSAL_createSrnsor, it was 35. Can anyone give some hints? Many thanks!
https://developer.nvidia.com/drive/learn/internal-tutorial-can
Hi Phil.Chen,
Could you check it with dwGetStatusName()? You can refer to /usr/local/driveworkssamples/src/framework/Checks.hpp.
Thank you VickNV!
