I figured not so, but worth doing a check here:
I run the ‘ARC’ compression code from izarc.org via a .exe file/program under Windows 7, 64bit.
Started some light reading on CUDA, which looks quite interesting. Don’t know C++, but I do know programming.
So, question is: Is there any feasible/practical way to have the .exe code run on CUDA/GPU processor(s) ?
Don’t know how much, if any parallelism could be done here, as I won’t be able to recompile the actual source code, but it would still be of benefit to have the task run on the GPU instead of the CPU.
Looking for ways to reduce the workload on my CPU and some sort of offloading of this to the GPU would be quite nice External Image
