Software Version
[*] DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
[*] 1.7.0.8846
other
Host Machine Version
[*] native Ubuntu 18.04
other
Hi, team,
I want encode 12 cameras using nvmedia_iep. And i notice instance ID only support 0~2 , so how to support 12cameras at same time ?
VickNV
November 10, 2021, 1:32pm
2
Hi, @wangxuhui1
Please share the code snippet about the instance ID so I can easily look into it. Thanks.
VickNV
November 10, 2021, 1:42pm
3
That’s hardware instances underneath. You can just use NVMEDIA_ENCODER_INSTANCE_AUTO, “2”. Please refer to NvMediaEncoderInstanceId .
hi @VickNV ,
yes i am using the api of nvmedia_iep
NvMediaIEP* NvMediaIEPCreate ( const NvMediaDevice * device,
NvMediaIEPType encodeType,
const void * initParams,
NvMediaSurfaceType inputFormat,
uint8_t maxInputBuffering,
uint8_t maxOutputBuffering,
NvMediaEncoderInstanceId instanceId
So does it support 12 cameras? Looks only support three instanceId at the same time. Any way can support 12 cameras?
VickNV
November 10, 2021, 1:58pm
6
Yes, you can follow Can h265 encoder support 12 camera? - #3 by VickNV to use auto one.
NVMEDIA_ENCODER_INSTANCE_AUTO: Specifies that the encoder instance ID can be set dynamically during encode.
Hi @wangxuhui1 :
Did you successfully encode 12 cameras at the same time?
Thank you.
