Can I change the link order of the PCIe Lannes?
For some special reasons, can I change the link order of the PCIe Lannes? As shown in the figure below
Although it may not work with stock BSP, the following change can be used to enable it.
Also, please note that the below change hasn’t been tried/verified. So, please apply it as an experimental suggestion.
diff --git a/drivers/pci/host/pci-tegra.c b/drivers/pci/host/pci-tegra.c
index 63c0e343d388..70b873c3203c 100644
--- a/drivers/pci/host/pci-tegra.c
+++ b/drivers/pci/host/pci-tegra.c
@@ -287,6 +287,16 @@
 #define PCIE2_RP_XP_REF_CPL_TO_CUSTOM_VALUE_MASK               (0x1FFFF << 14)
 #define PCIE2_RP_XP_REF_CPL_TO_CUSTOM_VALUE                    (0x1770 << 14)
+#define RP_VEND_XP_LANEMAP                                     0xFC0
+#define RP_VEND_XP_LANEMAP_SLOT_0                              GENMASK(3, 0)
+#define RP_VEND_XP_LANEMAP_SLOT_0_SHIFT                                0
+#define RP_VEND_XP_LANEMAP_SLOT_1                              GENMASK(7, 4)
+#define RP_VEND_XP_LANEMAP_SLOT_1_SHIFT                                4
+#define RP_VEND_XP_LANEMAP_SLOT_2                              GENMASK(11, 8)
+#define RP_VEND_XP_LANEMAP_SLOT_2_SHIFT                                8
+#define RP_VEND_XP_LANEMAP_SLOT_3                              GENMASK(15, 12)
+#define RP_VEND_XP_LANEMAP_SLOT_3_SHIFT                                12
 #define NV_PCIE2_RP_PRIV_MISC                                  0x00000FE0
 #define PCIE2_RP_PRIV_MISC_PRSNT_MAP_EP_PRSNT                  (0xE << 0)
 #define PCIE2_RP_PRIV_MISC_PRSNT_MAP_EP_ABSNT                  (0xF << 0)
@@ -2223,6 +2233,15 @@ static void tegra_pcie_apply_sw_war(struct tegra_pcie_port *port,
                data |= RP_LINK_CONTROL_STATUS_2_TRGT_LNK_SPD_GEN1;
                rp_writel(port, data, RP_LINK_CONTROL_STATUS_2);
+               data = rp_readl(port, RP_VEND_XP_LANEMAP);
+               data &= ~RP_VEND_XP_LANEMAP_SLOT_0;
+               data |= (2 << RP_VEND_XP_LANEMAP_SLOT_1_SHIFT);
+               data &= ~RP_VEND_XP_LANEMAP_SLOT_1;
+               data |= (0 << RP_VEND_XP_LANEMAP_SLOT_1_SHIFT);
+               data &= ~RP_VEND_XP_LANEMAP_SLOT_2;
+               data |= (1 << RP_VEND_XP_LANEMAP_SLOT_2_SHIFT);
+               rp_writel(port, data, RP_VEND_XP_LANEMAP);
                /* disable interrupts for LTR messages */
                data = rp_readl(port, PCIE2_RP_L1SS_SPARE);
                data &= ~PCIE2_RP_L1SS_SPARE_LTR_MSG_INT_EN;
thank you very much
