Thank for your reply so quickly!
I have a try to add a nvvideoconvert before video encoder as follows:
if (!bbox_enabled && (sr_mode == 0 || sr_mode == 1)) {
GstElement *queue_decode = gst_element_factory_make ("queue", NULL);
GstElement *decoder1 = gst_element_factory_make ("nvv4l2decoder", NULL);
GstElement *parser_pre_recordbin =
gst_element_factory_make ("h264parse", "parser-pre-recordbin");
GstElement *swconv_caps = gst_element_factory_make ("capsfilter", NULL);
GstCaps *conv_caps = gst_caps_from_string ("video/x-raw(memory:NVMM),format=(string)NV12,width=(int)320, height=(int)240");
g_object_set (G_OBJECT (swconv_caps), "caps", conv_caps, NULL);
gst_caps_unref (conv_caps);
GstElement *encoder =
gst_element_factory_make ("nvv4l2h264enc", "encoder");
GstElement *nvvidconv3 = gst_element_factory_make ("nvvideoconvert", "nvvidconv3");
gst_bin_add_many (GST_BIN (pipeline), queue_decode,decoder1,swconv_caps, nvvidconv3,encoder, NULL);
gst_bin_add_many (GST_BIN (pipeline), parser_pre_recordbin, NULL);
if (!gst_element_link_many (tee_pre_decode,queue_decode,decoder1,nvvidconv3,swconv_caps,encoder, parser_pre_recordbin,
nvdssrCtx->recordbin, NULL)) {
g_print ("Elements not linked. Exiting. \n");
g_main_loop_quit(loop);
gst_element_sync_state_with_parent(parser_pre_recordbin);
Now we can record a customed resolution video.
We meet a little problem at the first record which seems can be not synced firstly. But it will be fine at the next record.
Recording started..
In cb_newpad
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Opening in BLOCKING MODE
Stream format not found, dropping the frame
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
NVMEDIA: Need to set EMC bandwidth : 126000
NVMEDIA_ENC: bBlitMode is set to TRUE
Recording done.
Recording started..
Recording done.
