Can i change the rtsp source input dynamic
• Hardware Platform (Jetson / GPU): jetson xaiver
• DeepStream Version:v5.1
• JetPack Version (valid for Jetson only):jetpack 4.6
• TensorRT Version :tensorrt7
• Issue Type( questions, new requirements, bugs):questions
• Requirement details:In deepstream-test5, I have 6 rtsp input address.I config the config.txt for 4 input and 4 rtsp output.can i dynamic choose 4 rtsp input from the 6 rtsp address on deepstream test5 run time
• TensorRT Version
Thand you .i modify my answer
No. You can not change the uri dynamically with deepstream-test5.
You may implement the function by yourself. deepstream_reference_apps/runtime_source_add_delete at master · NVIDIA-AI-IOT/deepstream_reference_apps (github.com)
