I need to make sure the frame data is not currupted by MIPI errors.
- If MIPI error is occurred, how can the VI device driver let the app(v4l2) know it?
- If there is no check point of MIPI errors in device driver, how can I do for this?
Thank you.
Thank you.
Thank you for the information.
The document shows me how to enable the debug message of CSI, ISP, or something else.
But I need to know how to handle these errors in DEVICE DRIVER.
For example,
I want to check if there was an CSI double ECC error after being return “nvhost_syncpt_wait_timeout_ext” of vi4_ops.c
You can check the TRM for the REG information like REG NVCSI_STREAM_0_INTR_STATUS_VC0_0/NVCSI_PHY_0_CILA_INTR_0_STATUS_CILA_0 and modify the vi4_fops.c to read it to check the status to do what you want.
Okay thanks. :)
