Can I check the exact flashing time when I flash jetson NANO through sdkmanager?
Thank you.
If you only want the “flash time”, then you could use flash.sh and use the log printed on terminal to measure the time.
https://elinux.org/Jetson/General_debug
How can I measure the time it takes to install all components through sdkmanager?
Do you offer the ability to measure quantitatively?
Thank you
If you want to find the time to flash, then you could use the “time” command. For example:
sudo -s
time ./flash.sh jetson-nano-emmc mmcblk0p1
exit
You can experiment with “time” like this:
time sleep 2
“Real” time is real world time. You can probably ignore the other categories (unless you are interested in CPU load).
If you were to immediately run an operation with the actual SDK Manager, and exit immediately, then you could use “time” on that too, but I don’t know of a way to get the time of specific subsets of SDKM install, e.g., for optional package installs.
