Would it be possible to connect a 10GbE cable through PCIe on the AGX Xavier developer kit? Would there be any performance degradation?
Hi daluks,
If you want to connect 10Gb Ethernet NIC, then there should be no issue with respect to performance; if you’re not reaching expected performance you can try max cpu clock using jetson_maxclock.sh script on home folder.
