I use the deepstream-test3 example to display rtsp sources, and I can get the detected object information (e.g. x,y,w,h) from obj_meta in tiler_src_pad_buffer_probe(), but I don’t see where the function that draws the rectangle of bounding boxes.
I want to control the bounding box of detected objects drawn on frame or not, depending on position of bounding box, is possible?
