Can i control LCD1_BKLT_PWM?
hi
BSP version is R28.1
/sys/class/pwm/pwmchip0 --> LCD0_BKLT_PWM --> OK
/sys/class/pwm/pwmchip1 --> N/A
/sys/class/pwm/pwmchip2 --> LCD1_BKLT_PWM --> Not OK
/sys/class/pwm/pwmchip3 --> FAN_PWM --> OK
echo 0 | sudo tee -a /sys/class/pwm/pwmchip[port]/export
echo $period | sudo tee -a /sys/class/pwm/pwmchip[port]/pwm0/period
echo $duty | sudo tee -a /sys/class/pwm/pwmchip[port]/pwm0/duty_cycle
echo 1 | sudo tee -a /sys/class/pwm/pwmchip[port]/pwm0/enable
Can i control LCD1_BKLT_PWM ?
Hi walterkim,
Yes, please try to use above command to control PWM.
Refer to kernel documentation https://www.kernel.org/doc/Documentation/pwm.txt for information related to
sysfs node of pwm controllers that comes up on enabling pwm.
Now to configure the pwm with 20us period and 50% duty cycle through sysfs, do the following:
cd /sys/class/pwm/pwmchip0
echo 0 > export
cd pwm0
echo 20000 > period (20us is the total time period of the pulse)
echo 10000 > duty_cycle (50% duty cycle)
echo 1 > enable
Now if we probe the pwm lines we can see pwm pulse of period 20us and 50% duty cycle.
hi WayneWWW
I tested LCD1_BKLT_PWM. but there is no output. So I asked.
BSP version is R28.1(Jetson Tx2)
Hi walterkim,
Could you try to control GPIO pin U5?
hi WayneWWW
i tested U5 gpio.
it was controlled high/low.
but PWM was not controlled.
Hi walterkim,
Which device tree are you using?
Do you have similar configuration in device tree as below?
backlight {
                              status = "okay";
                              panel-s-wuxga-8-0-bl {
                                             pwms = <&tegra_pwm1 0 40161>;
                              panel-s-wqxga-10-1-bl {
                                             pwms = <&tegra_pwm1 0 1000000>;
                panel-s-edp-uhdtv-15-6-bl {
                        pwms = <&tegra_pwm3 0 5000000>;
                              panel-a-edp-1080p-14-0-bl {
               tegra_pwm1: pwm@3280000 {
                              status = "okay";
               tegra_pwm2: pwm@3290000 {
                              status = "okay";
               tegra_pwm3: pwm@32a0000 {
                              status = "okay";
               tegra_pwm4: pwm@c340000 {
                              status = "okay";
hi WayneWWW
yes!
It is the same as mine.
When you set gpio pin U5 to high, is there any output from that pin?
If yes, when you set this as steps in #3, is there any output?
hi WayneWWW
I tested below. PWM is not working.
//GPIO HIGH
echo 269 | sudo tee -a /sys/class/gpio/export
echo "out" | sudo tee -a /sys/class/gpio/gpio269/direction
echo "1" | sudo tee -a /sys/class/gpio/gpio269/value   <<<<<<<<<<<<<<<<< my scope displayed high
//PWM Enable
echo 0 | sudo tee -a /sys/class/pwm/pwmchip2/export
echo 33333333 | sudo tee -a /sys/class/pwm/pwmchip2/pwm0/period
echo 16666666 | sudo tee -a /sys/class/pwm/pwmchip2/pwm0/duty_cycle
echo 1 | sudo tee -a /sys/class/pwm/pwmchip2/pwm0/enable   <<<<<<<<<<<<<<< not output
HI walterkim,
Sorry for the late reply.
Could you share the value of.
root@tegra-ubuntu:/sys/kernel/debug# cat tegra-gpio-on
root@tegra-ubuntu:/sys/class/pwm/pwmchip2/pwm0# cat /sys/kernel/debug/tegra_pinctrl_reg
Also, Do you use custom pinmux or directly flashed by jetpack?
HI walterkim,
Please update previous question. Thanks.
hi WayeWWW
check please below
thank you
Port:Pin:ENB DBC IN OUT_CTRL OUT_VAL INT_CLR
S:0 0x0 0x0 0x0 0x1 0x0 0x0
S:1 0x0 0x0 0x0 0x1 0x0 0x0
S:2 0x0 0x0 0x0 0x1 0x0 0x0
S:3 0x4d 0x5 0x1 0x0 0x0 0x0
S:4 0x0 0x0 0x0 0x1 0x0 0x0
U:0 0x0 0x0 0x0 0x1 0x0 0x0
U:1 0x0 0x0 0x0 0x1 0x0 0x0
U:2 0x0 0x0 0x0 0x1 0x0 0x0
U:3 0x4d 0x5 0x1 0x0 0x0 0x0
U:4 0x0 0x0 0x0 0x1 0x0 0x0
U:5 0x0 0x0 0x0 0x1 0x0 0x0
V:0 0x45 0x0 0x1 0x1 0x0 0x0
V:1 0x0 0x0 0x0 0x1 0x0 0x0
V:2 0x0 0x0 0x0 0x1 0x0 0x0
V:3 0x0 0x0 0x0 0x1 0x0 0x0
V:4 0x0 0x0 0x0 0x1 0x0 0x0
V:5 0x3 0x0 0x0 0x0 0x0 0x0
V:6 0x0 0x0 0x0 0x1 0x0 0x0
V:7 0x0 0x0 0x0 0x1 0x0 0x0
W:0 0x0 0x0 0x0 0x1 0x0 0x0
W:1 0x0 0x0 0x0 0x1 0x0 0x0
W:2 0x0 0x0 0x0 0x1 0x0 0x0
W:3 0x0 0x0 0x0 0x1 0x0 0x0
W:4 0x0 0x0 0x0 0x1 0x0 0x0
W:5 0x0 0x0 0x0 0x1 0x0 0x0
W:6 0x0 0x0 0x0 0x1 0x0 0x0
W:7 0x0 0x0 0x0 0x1 0x0 0x0
Z:0 0x0 0x0 0x0 0x1 0x0 0x0
Z:1 0x0 0x0 0x0 0x1 0x0 0x0
Z:2 0x0 0x0 0x0 0x1 0x0 0x0
Z:3 0x0 0x0 0x0 0x1 0x0 0x0
AA:0 0x0 0x0 0x0 0x1 0x0 0x0
AA:1 0x0 0x0 0x0 0x1 0x0 0x0
AA:2 0x1 0x0 0x0 0x1 0x0 0x0
AA:3 0x1 0x0 0x1 0x1 0x0 0x0
AA:4 0x1 0x0 0x1 0x1 0x0 0x0
AA:5 0x1 0x0 0x1 0x1 0x0 0x0
AA:6 0x3 0x0 0x0 0x0 0x0 0x0
AA:7 0x1 0x0 0x1 0x1 0x0 0x0
EE:0 0x0 0x0 0x0 0x1 0x0 0x0
EE:1 0x0 0x0 0x0 0x1 0x0 0x0
EE:2 0x0 0x0 0x0 0x1 0x0 0x0
FF:0 0x4d 0x5 0x1 0x1 0x0 0x0
FF:1 0x4d 0x5 0x1 0x1 0x0 0x0
FF:2 0x1 0x0 0x1 0x1 0x0 0x0
FF:3 0x55 0x0 0x0 0x1 0x0 0x0
FF:4 0x59 0x0 0x0 0x1 0x0 0x0
root@tegra-ubuntu:/sys/kernel/debug# cat /sys/kernel/debug/tegra_pinctrl_reg
Bank: 1 Reg: 0x0c302000 Val: 0x00000400 -> touch_clk_pee2
Bank: 1 Reg: 0x0c302008 Val: 0x00000458 -> uart3_cts_pw5
Bank: 1 Reg: 0x0c302010 Val: 0x00000400 -> uart3_rts_pw4
Bank: 1 Reg: 0x0c302018 Val: 0x00000458 -> uart3_rx_pw3
Bank: 1 Reg: 0x0c302020 Val: 0x00000400 -> uart3_tx_pw2
Bank: 1 Reg: 0x0c302028 Val: 0x00001440 -> gen8_i2c_sda_pw1
Bank: 1 Reg: 0x0c302030 Val: 0x00001440 -> gen8_i2c_scl_pw0
Bank: 1 Reg: 0x0c302038 Val: 0x00000448 -> uart7_rx_pw7
Bank: 1 Reg: 0x0c302040 Val: 0x00000448 -> uart7_tx_pw6
Bank: 1 Reg: 0x0c302048 Val: 0x00000058 -> gpio_sen0_pv0
Bank: 1 Reg: 0x0c302050 Val: 0x00000444 -> gpio_sen1_pv1
Bank: 1 Reg: 0x0c302058 Val: 0x00000444 -> gpio_sen2_pv2
Bank: 1 Reg: 0x0c302060 Val: 0x00000444 -> gpio_sen3_pv3
Bank: 1 Reg: 0x0c302068 Val: 0x00000448 -> gpio_sen4_pv4
Bank: 1 Reg: 0x0c302070 Val: 0x00000000 -> gpio_sen5_pv5
Bank: 1 Reg: 0x0c302078 Val: 0x00000401 -> gpio_sen6_pv6
Bank: 1 Reg: 0x0c302080 Val: 0x00000401 -> gpio_sen7_pv7
Bank: 1 Reg: 0x0c302088 Val: 0x00001441 -> gpio_sen8_pee0
Bank: 1 Reg: 0x0c302090 Val: 0x00001441 -> gpio_sen9_pee1
Bank: 1 Reg: 0x0c303000 Val: 0x00000050 -> can_gpio7_paa7
Bank: 1 Reg: 0x0c303008 Val: 0x00000400 -> can1_dout_pz0
Bank: 1 Reg: 0x0c303010 Val: 0x00000458 -> can1_din_pz1
Bank: 1 Reg: 0x0c303018 Val: 0x00000400 -> can0_dout_pz2
Bank: 1 Reg: 0x0c303020 Val: 0x00000458 -> can0_din_pz3
Bank: 1 Reg: 0x0c303028 Val: 0x00006452 -> can_gpio0_paa0
Bank: 1 Reg: 0x0c303030 Val: 0x00006402 -> can_gpio1_paa1
Bank: 1 Reg: 0x0c303038 Val: 0x00000059 -> can_gpio2_paa2
Bank: 1 Reg: 0x0c303040 Val: 0x00000040 -> can_gpio3_paa3
Bank: 1 Reg: 0x0c303048 Val: 0x00000058 -> can_gpio4_paa4
Bank: 1 Reg: 0x0c303050 Val: 0x00000040 -> can_gpio5_paa5
Bank: 1 Reg: 0x0c303058 Val: 0x00000000 -> can_gpio6_paa6
Bank: 0 Reg: 0x02431000 Val: 0x00000401 -> gpio_aud3_pk0
Bank: 0 Reg: 0x02431008 Val: 0x00000401 -> gpio_aud2_pj7
Bank: 0 Reg: 0x02431010 Val: 0x00000000 -> gpio_aud1_pj6
Bank: 0 Reg: 0x02431018 Val: 0x00000058 -> gpio_aud0_pj5
Bank: 0 Reg: 0x02431020 Val: 0x00000400 -> aud_mclk_pj4
Bank: 0 Reg: 0x02431028 Val: 0x00000440 -> dap1_fs_pj3
Bank: 0 Reg: 0x02431030 Val: 0x00000450 -> dap1_din_pj2
Bank: 0 Reg: 0x02431038 Val: 0x00000440 -> dap1_dout_pj1
Bank: 0 Reg: 0x02431040 Val: 0x00000440 -> dap1_sclk_pj0
Bank: 0 Reg: 0x02432000 Val: 0x00006441 -> dmic1_clk_pm1
Bank: 0 Reg: 0x02432008 Val: 0x00006451 -> dmic1_dat_pm0
Bank: 0 Reg: 0x02432010 Val: 0x00006441 -> dmic2_dat_pm2
Bank: 0 Reg: 0x02432018 Val: 0x00006441 -> dmic2_clk_pm3
Bank: 0 Reg: 0x02432020 Val: 0x00006002 -> dmic4_dat_pm4
Bank: 0 Reg: 0x02432028 Val: 0x0000605a -> dmic4_clk_pm5
Bank: 0 Reg: 0x02432030 Val: 0x00006440 -> dap4_fs_pcc3
Bank: 0 Reg: 0x02432038 Val: 0x00006450 -> dap4_din_pcc2
Bank: 0 Reg: 0x02432040 Val: 0x00006440 -> dap4_dout_pcc1
Bank: 0 Reg: 0x02432048 Val: 0x00006440 -> dap4_sclk_pcc0
Bank: 0 Reg: 0x02430000 Val: 0x00000400 -> extperiph2_clk_po1
Bank: 0 Reg: 0x02430008 Val: 0x00000400 -> extperiph1_clk_po0
Bank: 0 Reg: 0x02430010 Val: 0x00001440 -> cam_i2c_sda_po3
Bank: 0 Reg: 0x02430018 Val: 0x00001440 -> cam_i2c_scl_po2
Bank: 0 Reg: 0x02430020 Val: 0x00000001 -> gpio_cam1_pn0
Bank: 0 Reg: 0x02430028 Val: 0x00000401 -> gpio_cam2_pn1
Bank: 0 Reg: 0x02430030 Val: 0x00000002 -> gpio_cam3_pn2
Bank: 0 Reg: 0x02430038 Val: 0x00000445 -> gpio_cam4_pn3
Bank: 0 Reg: 0x02430040 Val: 0x00000445 -> gpio_cam5_pn4
Bank: 0 Reg: 0x02430048 Val: 0x00000445 -> gpio_cam6_pn5
Bank: 0 Reg: 0x02430050 Val: 0x00000449 -> gpio_cam7_pn6
Bank: 0 Reg: 0x02434000 Val: 0x00000450 -> dap2_din_pc3
Bank: 0 Reg: 0x02434008 Val: 0x00000440 -> dap2_dout_pc2
Bank: 0 Reg: 0x02434010 Val: 0x00000440 -> dap2_fs_pc4
Bank: 0 Reg: 0x02434018 Val: 0x00000440 -> dap2_sclk_pc1
Bank: 0 Reg: 0x02434020 Val: 0x00000458 -> uart4_cts_pb3
Bank: 0 Reg: 0x02434028 Val: 0x00000400 -> uart4_rts_pb2
Bank: 0 Reg: 0x02434030 Val: 0x00000458 -> uart4_rx_pb1
Bank: 0 Reg: 0x02434038 Val: 0x00000400 -> uart4_tx_pb0
Bank: 0 Reg: 0x02434040 Val: 0x00000048 -> gpio_wan4_pc0
Bank: 0 Reg: 0x02434048 Val: 0x00000000 -> gpio_wan3_pb6
Bank: 0 Reg: 0x02434050 Val: 0x00000048 -> gpio_wan2_pb5
Bank: 0 Reg: 0x02434058 Val: 0x00000000 -> gpio_wan1_pb4
Bank: 0 Reg: 0x02434060 Val: 0x00001460 -> gen1_i2c_scl_pc5
Bank: 0 Reg: 0x02434068 Val: 0x00001460 -> gen1_i2c_sda_pc6
Bank: 0 Reg: 0x02435000 Val: 0x00000401 -> uart1_cts_pt3
Bank: 0 Reg: 0x02435008 Val: 0x00000401 -> uart1_rts_pt2
Bank: 0 Reg: 0x02435010 Val: 0x00000458 -> uart1_rx_pt1
Bank: 0 Reg: 0x02435018 Val: 0x00000400 -> uart1_tx_pt0
Bank: 0 Reg: 0x02435028 Val: 0x00022448 -> directdc1_out3_pq5
Bank: 0 Reg: 0x02435030 Val: 0x00022448 -> directdc1_out2_pq4
Bank: 0 Reg: 0x02435038 Val: 0x00022448 -> directdc1_out1_pq3
Bank: 0 Reg: 0x02435040 Val: 0x00022448 -> directdc1_out0_pq2
Bank: 0 Reg: 0x02435048 Val: 0x00022444 -> directdc1_in_pq1
Bank: 0 Reg: 0x02435050 Val: 0x00022448 -> directdc1_clk_pq0
Bank: 0 Reg: 0x02435058 Val: 0x00002000 -> directdc_comp
Bank: 0 Reg: 0x02433000 Val: 0x00006446 -> gpio_pq0_pi0
Bank: 0 Reg: 0x02433008 Val: 0x00006446 -> gpio_pq1_pi1
Bank: 0 Reg: 0x02433010 Val: 0x00006456 -> gpio_pq2_pi2
Bank: 0 Reg: 0x02433018 Val: 0x00006446 -> gpio_pq3_pi3
Bank: 0 Reg: 0x02433020 Val: 0x00004058 -> gpio_pq4_pi4
Bank: 0 Reg: 0x02433028 Val: 0x00004000 -> gpio_pq5_pi5
Bank: 0 Reg: 0x02433030 Val: 0x00004048 -> gpio_pq6_pi6
Bank: 0 Reg: 0x02433038 Val: 0x00004044 -> gpio_pq7_pi7
Bank: 0 Reg: 0x02440000 Val: 0x00000158 -> gpio_edp2_pp5
Bank: 0 Reg: 0x02440008 Val: 0x00000000 -> gpio_edp3_pp6
Bank: 0 Reg: 0x02440010 Val: 0x00000040 -> gpio_edp0_pp3
Bank: 0 Reg: 0x02440018 Val: 0x00000058 -> gpio_edp1_pp4
Bank: 0 Reg: 0x02440020 Val: 0x00000550 -> dp_aux_ch0_hpd_pp0
Bank: 0 Reg: 0x02440028 Val: 0x00000151 -> dp_aux_ch1_hpd_pp1
Bank: 0 Reg: 0x02440030 Val: 0x00000560 -> hdmi_cec_pp2
Bank: 0 Reg: 0x02437000 Val: 0x00000560 -> pex_l2_clkreq_n_pa6
Bank: 0 Reg: 0x02437008 Val: 0x00000570 -> pex_wake_n_pa2
Bank: 0 Reg: 0x02437010 Val: 0x00000560 -> pex_l1_clkreq_n_pa4
Bank: 0 Reg: 0x02437018 Val: 0x00000520 -> pex_l1_rst_n_pa3
Bank: 0 Reg: 0x02437020 Val: 0x00000560 -> pex_l0_clkreq_n_pa1
Bank: 0 Reg: 0x02437028 Val: 0x00000520 -> pex_l0_rst_n_pa0
Bank: 0 Reg: 0x02437030 Val: 0x00000520 -> pex_l2_rst_n_pa5
Bank: 0 Reg: 0x02438000 Val: 0x00002460 -> sdmmc1_clk_pd0
Bank: 0 Reg: 0x02438008 Val: 0x00002448 -> sdmmc1_cmd_pd1
Bank: 0 Reg: 0x02438010 Val: 0x00000000 -> sdmmc1_comp
Bank: 0 Reg: 0x02438014 Val: 0x00002448 -> sdmmc1_dat3_pd5
Bank: 0 Reg: 0x0243801c Val: 0x00002448 -> sdmmc1_dat2_pd4
Bank: 0 Reg: 0x02438024 Val: 0x00002448 -> sdmmc1_dat1_pd3
Bank: 0 Reg: 0x0243802c Val: 0x00002448 -> sdmmc1_dat0_pd2
Bank: 0 Reg: 0x02439000 Val: 0x00002400 -> eqos_td3_pe4
Bank: 0 Reg: 0x02439008 Val: 0x00002400 -> eqos_td2_pe3
Bank: 0 Reg: 0x02439010 Val: 0x00002400 -> eqos_td1_pe2
Bank: 0 Reg: 0x02439018 Val: 0x00002400 -> eqos_td0_pe1
Bank: 0 Reg: 0x02439020 Val: 0x00002450 -> eqos_rd3_pf1
Bank: 0 Reg: 0x02439028 Val: 0x00002450 -> eqos_rd2_pf0
Bank: 0 Reg: 0x02439030 Val: 0x00002450 -> eqos_rd1_pe7
Bank: 0 Reg: 0x02439038 Val: 0x00002448 -> eqos_mdio_pf4
Bank: 0 Reg: 0x02439040 Val: 0x00002450 -> eqos_rd0_pe6
Bank: 0 Reg: 0x02439048 Val: 0x00002400 -> eqos_mdc_pf5
Bank: 0 Reg: 0x02439050 Val: 0x00000000 -> eqos_comp
Bank: 0 Reg: 0x02439054 Val: 0x00002400 -> eqos_txc_pe0
Bank: 0 Reg: 0x0243905c Val: 0x00002450 -> eqos_rxc_pf3
Bank: 0 Reg: 0x02439064 Val: 0x00002400 -> eqos_tx_ctl_pe5
Bank: 0 Reg: 0x0243906c Val: 0x00002450 -> eqos_rx_ctl_pf2
Bank: 0 Reg: 0x0243a000 Val: 0x00002448 -> sdmmc3_dat3_pg5
Bank: 0 Reg: 0x0243a008 Val: 0x00002448 -> sdmmc3_dat2_pg4
Bank: 0 Reg: 0x0243a010 Val: 0x00002448 -> sdmmc3_dat1_pg3
Bank: 0 Reg: 0x0243a018 Val: 0x00002448 -> sdmmc3_dat0_pg2
Bank: 0 Reg: 0x0243a020 Val: 0x00000000 -> sdmmc3_comp
Bank: 0 Reg: 0x0243a024 Val: 0x00002448 -> sdmmc3_cmd_pg1
Bank: 0 Reg: 0x0243a02c Val: 0x00002460 -> sdmmc3_clk_pg0
Bank: 0 Reg: 0x02436004 Val: 0x00002060 -> sdmmc4_clk
Bank: 0 Reg: 0x02436008 Val: 0x00002048 -> sdmmc4_cmd
Bank: 0 Reg: 0x0243600c Val: 0x00002040 -> sdmmc4_dqs
Bank: 0 Reg: 0x02436010 Val: 0x00002048 -> sdmmc4_dat7
Bank: 0 Reg: 0x02436014 Val: 0x00002048 -> sdmmc4_dat6
Bank: 0 Reg: 0x02436018 Val: 0x00002048 -> sdmmc4_dat5
Bank: 0 Reg: 0x0243601c Val: 0x00002048 -> sdmmc4_dat4
Bank: 0 Reg: 0x02436020 Val: 0x00002048 -> sdmmc4_dat3
Bank: 0 Reg: 0x02436024 Val: 0x00002048 -> sdmmc4_dat2
Bank: 0 Reg: 0x02436028 Val: 0x00002048 -> sdmmc4_dat1
Bank: 0 Reg: 0x0243602c Val: 0x00002048 -> sdmmc4_dat0
Bank: 0 Reg: 0x0243b000 Val: 0x00000001 -> qspi_io3_pr4
Bank: 0 Reg: 0x0243b008 Val: 0x00000001 -> qspi_io2_pr3
Bank: 0 Reg: 0x0243b010 Val: 0x00000001 -> qspi_io1_pr2
Bank: 0 Reg: 0x0243b018 Val: 0x00000001 -> qspi_io0_pr1
Bank: 0 Reg: 0x0243b020 Val: 0x00000001 -> qspi_sck_pr0
Bank: 0 Reg: 0x0243b028 Val: 0x00000059 -> qspi_cs_n_pr5
Bank: 0 Reg: 0x0243b030 Val: 0x00002000 -> qspi_comp
Bank: 1 Reg: 0x0c301000 Val: 0x00000058 -> gpio_sw1_pff1
Bank: 1 Reg: 0x0c301008 Val: 0x00000058 -> gpio_sw2_pff2
Bank: 1 Reg: 0x0c301010 Val: 0x00000058 -> gpio_sw3_pff3
Bank: 1 Reg: 0x0c301018 Val: 0x00000058 -> gpio_sw4_pff4
Bank: 1 Reg: 0x0c301020 Val: 0x00000040 -> shutdown
Bank: 1 Reg: 0x0c301028 Val: 0x00000040 -> pmu_int
Bank: 1 Reg: 0x0c301030 Val: 0x00000041 -> safe_state_ps3
Bank: 1 Reg: 0x0c301038 Val: 0x00000458 -> vcomp_alert_ps4
Bank: 1 Reg: 0x0c301040 Val: 0x00000040 -> soc_pwr_req
Bank: 1 Reg: 0x0c301048 Val: 0x00000458 -> batt_oc_ps2
Bank: 1 Reg: 0x0c301050 Val: 0x00001040 -> clk_32k_in
Bank: 1 Reg: 0x0c301058 Val: 0x00000058 -> power_on_pff0
Bank: 1 Reg: 0x0c301060 Val: 0x00001440 -> pwr_i2c_scl_ps0
Bank: 1 Reg: 0x0c301068 Val: 0x00001440 -> pwr_i2c_sda_ps1
Bank: 1 Reg: 0x0c301080 Val: 0x00000401 -> gpio_dis0_pu0
Bank: 1 Reg: 0x0c301088 Val: 0x00000456 -> gpio_dis1_pu1
Bank: 1 Reg: 0x0c301090 Val: 0x00000402 -> gpio_dis2_pu2
Bank: 1 Reg: 0x0c301098 Val: 0x00000040 -> gpio_dis3_pu3
Bank: 1 Reg: 0x0c3010a0 Val: 0x00000402 -> gpio_dis4_pu4
Bank: 1 Reg: 0x0c3010a8 Val: 0x00000411 -> gpio_dis5_pu5
Bank: 0 Reg: 0x0243d000 Val: 0x0000044a -> gpio_wan8_ph3
Bank: 0 Reg: 0x0243d008 Val: 0x00000446 -> gpio_wan7_ph2
Bank: 0 Reg: 0x0243d010 Val: 0x00000446 -> gpio_wan6_ph1
Bank: 0 Reg: 0x0243d018 Val: 0x00000446 -> gpio_wan5_ph0
Bank: 0 Reg: 0x0243d020 Val: 0x00000400 -> uart2_tx_px0
Bank: 0 Reg: 0x0243d028 Val: 0x00000458 -> uart2_rx_px1
Bank: 0 Reg: 0x0243d030 Val: 0x00000400 -> uart2_rts_px2
Bank: 0 Reg: 0x0243d038 Val: 0x00000458 -> uart2_cts_px3
Bank: 0 Reg: 0x0243d040 Val: 0x00000402 -> uart5_rx_px5
Bank: 0 Reg: 0x0243d048 Val: 0x00000452 -> uart5_tx_px4
Bank: 0 Reg: 0x0243d050 Val: 0x00000002 -> uart5_rts_px6
Bank: 0 Reg: 0x0243d058 Val: 0x0000005a -> uart5_cts_px7
Bank: 0 Reg: 0x0243d060 Val: 0x00000058 -> gpio_mdm1_py0
Bank: 0 Reg: 0x0243d068 Val: 0x00000058 -> gpio_mdm2_py1
Bank: 0 Reg: 0x0243d070 Val: 0x00000058 -> gpio_mdm3_py2
Bank: 0 Reg: 0x0243d078 Val: 0x00000409 -> gpio_mdm4_py3
Bank: 0 Reg: 0x0243d080 Val: 0x00000000 -> gpio_mdm5_py4
Bank: 0 Reg: 0x0243d088 Val: 0x00000059 -> gpio_mdm6_py5
Bank: 0 Reg: 0x0243d090 Val: 0x00000058 -> gpio_mdm7_py6
Bank: 0 Reg: 0x0243d098 Val: 0x00000000 -> bcpu_pwr_req_ph4
Bank: 0 Reg: 0x0243d0a0 Val: 0x00000000 -> mcpu_pwr_req_ph5
Bank: 0 Reg: 0x0243d0a8 Val: 0x00000000 -> gpu_pwr_req_ph6
Bank: 0 Reg: 0x0243d0b0 Val: 0x00001440 -> gen7_i2c_scl_pl0
Bank: 0 Reg: 0x0243d0b8 Val: 0x00001440 -> gen7_i2c_sda_pl1
Bank: 0 Reg: 0x0243d0c0 Val: 0x00001440 -> gen9_i2c_sda_pl3
Bank: 0 Reg: 0x0243d0c8 Val: 0x00001440 -> gen9_i2c_scl_pl2
Bank: 0 Reg: 0x0243d0d0 Val: 0x00000460 -> usb_vbus_en0_pl4
Bank: 0 Reg: 0x0243d0d8 Val: 0x00000470 -> usb_vbus_en1_pl5
Bank: 0 Reg: 0x0243d0e0 Val: 0x00000400 -> gp_pwm7_pl7
Bank: 0 Reg: 0x0243d0e8 Val: 0x00000400 -> gp_pwm6_pl6
Bank: 0 Reg: 0x02441000 Val: 0x00022001 -> ufs0_rst_pbb1
Bank: 0 Reg: 0x02441008 Val: 0x00022001 -> ufs0_ref_clk_pbb0
Bank: 1 Reg: 0x0c302004 Val: 0x00000000 -> drive_touch_clk
Bank: 1 Reg: 0x0c30200c Val: 0x00606000 -> drive_uart3_cts
Bank: 1 Reg: 0x0c302014 Val: 0x00606000 -> drive_uart3_rts
Bank: 1 Reg: 0x0c30201c Val: 0x00606000 -> drive_uart3_rx
Bank: 1 Reg: 0x0c302024 Val: 0x00606000 -> drive_uart3_tx
Bank: 1 Reg: 0x0c30202c Val: 0x0001f000 -> drive_gen8_i2c_sda
Bank: 1 Reg: 0x0c302034 Val: 0x0001f000 -> drive_gen8_i2c_scl
Bank: 1 Reg: 0x0c30203c Val: 0x00606000 -> drive_uart7_rx
Bank: 1 Reg: 0x0c302044 Val: 0x00606000 -> drive_uart7_tx
Bank: 1 Reg: 0x0c30204c Val: 0x00000000 -> drive_gpio_sen0
Bank: 1 Reg: 0x0c302054 Val: 0x00000000 -> drive_gpio_sen1
Bank: 1 Reg: 0x0c30205c Val: 0x00000000 -> drive_gpio_sen2
Bank: 1 Reg: 0x0c302064 Val: 0x00000000 -> drive_gpio_sen3
Bank: 1 Reg: 0x0c30206c Val: 0x00000000 -> drive_gpio_sen4
Bank: 1 Reg: 0x0c302074 Val: 0x00000000 -> drive_gpio_sen5
Bank: 1 Reg: 0x0c30207c Val: 0x00000000 -> drive_gpio_sen6
Bank: 1 Reg: 0x0c302084 Val: 0x00000000 -> drive_gpio_sen7
Bank: 1 Reg: 0x0c30208c Val: 0x0001f000 -> drive_gpio_sen8
Bank: 1 Reg: 0x0c302094 Val: 0x0001f000 -> drive_gpio_sen9
Bank: 1 Reg: 0x0c303004 Val: 0x00000000 -> drive_can_gpio7
Bank: 1 Reg: 0x0c30300c Val: 0x00000000 -> drive_can1_dout
Bank: 1 Reg: 0x0c303014 Val: 0x00000000 -> drive_can1_din
Bank: 1 Reg: 0x0c30301c Val: 0x00000000 -> drive_can0_dout
Bank: 1 Reg: 0x0c303024 Val: 0x00000000 -> drive_can0_din
Bank: 1 Reg: 0x0c30302c Val: 0xf0000000 -> drive_can_gpio0
Bank: 1 Reg: 0x0c303034 Val: 0xf0000000 -> drive_can_gpio1
Bank: 1 Reg: 0x0c30303c Val: 0x00000000 -> drive_can_gpio2
Bank: 1 Reg: 0x0c303044 Val: 0x00000000 -> drive_can_gpio3
Bank: 1 Reg: 0x0c30304c Val: 0x00000000 -> drive_can_gpio4
Bank: 1 Reg: 0x0c303054 Val: 0x00000000 -> drive_can_gpio5
Bank: 1 Reg: 0x0c30305c Val: 0x00000000 -> drive_can_gpio6
Bank: 0 Reg: 0x02431004 Val: 0x01f1f000 -> drive_gpio_aud3
Bank: 0 Reg: 0x0243100c Val: 0x01f1f000 -> drive_gpio_aud2
Bank: 0 Reg: 0x02431014 Val: 0x00000000 -> drive_gpio_aud1
Bank: 0 Reg: 0x0243101c Val: 0x00000000 -> drive_gpio_aud0
Bank: 0 Reg: 0x02431024 Val: 0x00708000 -> drive_aud_mclk
Bank: 0 Reg: 0x0243102c Val: 0x01616000 -> drive_dap1_fs
Bank: 0 Reg: 0x02431034 Val: 0x01616000 -> drive_dap1_din
Bank: 0 Reg: 0x0243103c Val: 0x01616000 -> drive_dap1_dout
Bank: 0 Reg: 0x02431044 Val: 0x01616000 -> drive_dap1_sclk
Bank: 0 Reg: 0x02432004 Val: 0xf0000000 -> drive_dmic1_clk
Bank: 0 Reg: 0x0243200c Val: 0xf0000000 -> drive_dmic1_dat
Bank: 0 Reg: 0x02432014 Val: 0xf0000000 -> drive_dmic2_dat
Bank: 0 Reg: 0x0243201c Val: 0xf0000000 -> drive_dmic2_clk
Bank: 0 Reg: 0x02432024 Val: 0xf0000000 -> drive_dmic4_dat
Bank: 0 Reg: 0x0243202c Val: 0xf0000000 -> drive_dmic4_clk
Bank: 0 Reg: 0x02432034 Val: 0xf0000000 -> drive_dap4_fs
Bank: 0 Reg: 0x0243203c Val: 0xf0000000 -> drive_dap4_din
Bank: 0 Reg: 0x02432044 Val: 0xf0000000 -> drive_dap4_dout
Bank: 0 Reg: 0x0243204c Val: 0xf0000000 -> drive_dap4_sclk
Bank: 0 Reg: 0x02430004 Val: 0x00000000 -> drive_extperiph2_clk
Bank: 0 Reg: 0x0243000c Val: 0x00000000 -> drive_extperiph1_clk
Bank: 0 Reg: 0x02430014 Val: 0x0001f000 -> drive_cam_i2c_sda
Bank: 0 Reg: 0x0243001c Val: 0x0001f000 -> drive_cam_i2c_scl
Bank: 0 Reg: 0x02430024 Val: 0x00000000 -> drive_gpio_cam1
Bank: 0 Reg: 0x0243002c Val: 0x00000000 -> drive_gpio_cam2
Bank: 0 Reg: 0x02430034 Val: 0x00000000 -> drive_gpio_cam3
Bank: 0 Reg: 0x0243003c Val: 0x00000000 -> drive_gpio_cam4
Bank: 0 Reg: 0x02430044 Val: 0x00000000 -> drive_gpio_cam5
Bank: 0 Reg: 0x0243004c Val: 0x00000000 -> drive_gpio_cam6
Bank: 0 Reg: 0x02430054 Val: 0x00000000 -> drive_gpio_cam7
Bank: 0 Reg: 0x02434004 Val: 0x01616000 -> drive_dap2_din
Bank: 0 Reg: 0x0243400c Val: 0x01616000 -> drive_dap2_dout
Bank: 0 Reg: 0x02434014 Val: 0x01616000 -> drive_dap2_fs
Bank: 0 Reg: 0x0243401c Val: 0x01616000 -> drive_dap2_sclk
Bank: 0 Reg: 0x02434024 Val: 0x00606000 -> drive_uart4_cts
Bank: 0 Reg: 0x0243402c Val: 0x00606000 -> drive_uart4_rts
Bank: 0 Reg: 0x02434034 Val: 0x00606000 -> drive_uart4_rx
Bank: 0 Reg: 0x0243403c Val: 0x00606000 -> drive_uart4_tx
Bank: 0 Reg: 0x02434044 Val: 0x00000000 -> drive_gpio_wan4
Bank: 0 Reg: 0x0243404c Val: 0x00000000 -> drive_gpio_wan3
Bank: 0 Reg: 0x02434054 Val: 0x00000000 -> drive_gpio_wan2
Bank: 0 Reg: 0x0243405c Val: 0x00000000 -> drive_gpio_wan1
Bank: 0 Reg: 0x02434064 Val: 0x0001f000 -> drive_gen1_i2c_scl
Bank: 0 Reg: 0x0243406c Val: 0x0001f000 -> drive_gen1_i2c_sda
Bank: 0 Reg: 0x02435004 Val: 0x00606000 -> drive_uart1_cts
Bank: 0 Reg: 0x0243500c Val: 0x00606000 -> drive_uart1_rts
Bank: 0 Reg: 0x02435014 Val: 0x00606000 -> drive_uart1_rx
Bank: 0 Reg: 0x0243501c Val: 0x00606000 -> drive_uart1_tx
Bank: 0 Reg: 0x0243502c Val: 0x00000000 -> drive_directdc1_out3
Bank: 0 Reg: 0x02435034 Val: 0x00000000 -> drive_directdc1_out2
Bank: 0 Reg: 0x0243503c Val: 0x00000000 -> drive_directdc1_out1
Bank: 0 Reg: 0x02435044 Val: 0x00000000 -> drive_directdc1_out0
Bank: 0 Reg: 0x0243504c Val: 0x00000000 -> drive_directdc1_in
Bank: 0 Reg: 0x02435054 Val: 0x00000000 -> drive_directdc1_clk
Bank: 0 Reg: 0x02433004 Val: 0xf0000000 -> drive_gpio_pq0
Bank: 0 Reg: 0x0243300c Val: 0xf0000000 -> drive_gpio_pq1
Bank: 0 Reg: 0x02433014 Val: 0xf0000000 -> drive_gpio_pq2
Bank: 0 Reg: 0x0243301c Val: 0xf0000000 -> drive_gpio_pq3
Bank: 0 Reg: 0x02433024 Val: 0x00000000 -> drive_gpio_pq4
Bank: 0 Reg: 0x0243302c Val: 0x00000000 -> drive_gpio_pq5
Bank: 0 Reg: 0x02433034 Val: 0x00000000 -> drive_gpio_pq6
Bank: 0 Reg: 0x0243303c Val: 0x00000000 -> drive_gpio_pq7
Bank: 0 Reg: 0x02440004 Val: 0x00606000 -> drive_gpio_edp2
Bank: 0 Reg: 0x0244000c Val: 0x00606000 -> drive_gpio_edp3
Bank: 0 Reg: 0x02440014 Val: 0x00606000 -> drive_gpio_edp0
Bank: 0 Reg: 0x0244001c Val: 0x00606000 -> drive_gpio_edp1
Bank: 0 Reg: 0x02440024 Val: 0x00000000 -> drive_dp_aux_ch0_hpd
Bank: 0 Reg: 0x0244002c Val: 0x00000000 -> drive_dp_aux_ch1_hpd
Bank: 0 Reg: 0x02440034 Val: 0x00000000 -> drive_hdmi_cec
Bank: 0 Reg: 0x02437004 Val: 0x00000000 -> drive_pex_l2_clkreq_n
Bank: 0 Reg: 0x0243700c Val: 0x00000000 -> drive_pex_wake_n
Bank: 0 Reg: 0x02437014 Val: 0x00000000 -> drive_pex_l1_clkreq_n
Bank: 0 Reg: 0x0243701c Val: 0x00000000 -> drive_pex_l1_rst_n
Bank: 0 Reg: 0x02437024 Val: 0x00000000 -> drive_pex_l0_clkreq_n
Bank: 0 Reg: 0x0243702c Val: 0x00000000 -> drive_pex_l0_rst_n
Bank: 0 Reg: 0x02437034 Val: 0x00000000 -> drive_pex_l2_rst_n
Bank: 0 Reg: 0x02438004 Val: 0x00000000 -> drive_sdmmc1_clk
Bank: 0 Reg: 0x0243800c Val: 0x00000000 -> drive_sdmmc1_cmd
Bank: 0 Reg: 0x02438018 Val: 0x00000000 -> drive_sdmmc1_dat3
Bank: 0 Reg: 0x02438020 Val: 0x00000000 -> drive_sdmmc1_dat2
Bank: 0 Reg: 0x02438028 Val: 0x00000000 -> drive_sdmmc1_dat1
Bank: 0 Reg: 0x02438030 Val: 0x00000000 -> drive_sdmmc1_dat0
Bank: 0 Reg: 0x02439004 Val: 0x00000000 -> drive_eqos_td3
Bank: 0 Reg: 0x0243900c Val: 0x00000000 -> drive_eqos_td2
Bank: 0 Reg: 0x02439014 Val: 0x00000000 -> drive_eqos_td1
Bank: 0 Reg: 0x0243901c Val: 0x00000000 -> drive_eqos_td0
Bank: 0 Reg: 0x02439024 Val: 0x00000000 -> drive_eqos_rd3
Bank: 0 Reg: 0x0243902c Val: 0x00000000 -> drive_eqos_rd2
Bank: 0 Reg: 0x02439034 Val: 0x00000000 -> drive_eqos_rd1
Bank: 0 Reg: 0x0243903c Val: 0x00000000 -> drive_eqos_mdio
Bank: 0 Reg: 0x02439044 Val: 0x00000000 -> drive_eqos_rd0
Bank: 0 Reg: 0x0243904c Val: 0x00000000 -> drive_eqos_mdc
Bank: 0 Reg: 0x02439058 Val: 0x00000000 -> drive_eqos_txc
Bank: 0 Reg: 0x02439060 Val: 0x00000000 -> drive_eqos_rxc
Bank: 0 Reg: 0x02439068 Val: 0x00000000 -> drive_eqos_tx_ctl
Bank: 0 Reg: 0x02439070 Val: 0x00000000 -> drive_eqos_rx_ctl
Bank: 0 Reg: 0x0243a004 Val: 0x00000000 -> drive_sdmmc3_dat3
Bank: 0 Reg: 0x0243a00c Val: 0x00000000 -> drive_sdmmc3_dat2
Bank: 0 Reg: 0x0243a014 Val: 0x00000000 -> drive_sdmmc3_dat1
Bank: 0 Reg: 0x0243a01c Val: 0x00000000 -> drive_sdmmc3_dat0
Bank: 0 Reg: 0x0243a028 Val: 0x00000000 -> drive_sdmmc3_cmd
Bank: 0 Reg: 0x0243a030 Val: 0x00000000 -> drive_sdmmc3_clk
Bank: 0 Reg: 0x0243b004 Val: 0x00000000 -> drive_qspi_io3
Bank: 0 Reg: 0x0243b00c Val: 0x00000000 -> drive_qspi_io2
Bank: 0 Reg: 0x0243b014 Val: 0x00000000 -> drive_qspi_io1
Bank: 0 Reg: 0x0243b01c Val: 0x00000000 -> drive_qspi_io0
Bank: 0 Reg: 0x0243b024 Val: 0x00000000 -> drive_qspi_sck
Bank: 0 Reg: 0x0243b02c Val: 0x00000000 -> drive_qspi_cs_n
Bank: 1 Reg: 0x0c301004 Val: 0x00000000 -> drive_gpio_sw1
Bank: 1 Reg: 0x0c30100c Val: 0x00000000 -> drive_gpio_sw2
Bank: 1 Reg: 0x0c301014 Val: 0x00000000 -> drive_gpio_sw3
Bank: 1 Reg: 0x0c30101c Val: 0x00000000 -> drive_gpio_sw4
Bank: 1 Reg: 0x0c301024 Val: 0x00000000 -> drive_shutdown
Bank: 1 Reg: 0x0c30102c Val: 0x00000000 -> drive_pmu_int
Bank: 1 Reg: 0x0c301034 Val: 0x00000000 -> drive_safe_state
Bank: 1 Reg: 0x0c30103c Val: 0x00000000 -> drive_vcomp_alert
Bank: 1 Reg: 0x0c301044 Val: 0x00000000 -> drive_soc_pwr_req
Bank: 1 Reg: 0x0c30104c Val: 0x00000000 -> drive_batt_oc
Bank: 1 Reg: 0x0c301054 Val: 0x00000000 -> drive_clk_32k_in
Bank: 1 Reg: 0x0c30105c Val: 0x00000000 -> drive_power_on
Bank: 1 Reg: 0x0c301064 Val: 0x0001f000 -> drive_pwr_i2c_scl
Bank: 1 Reg: 0x0c30106c Val: 0x0001f000 -> drive_pwr_i2c_sda
Bank: 1 Reg: 0x0c301084 Val: 0x00000000 -> drive_gpio_dis0
Bank: 1 Reg: 0x0c30108c Val: 0x00000000 -> drive_gpio_dis1
Bank: 1 Reg: 0x0c301094 Val: 0x00000000 -> drive_gpio_dis2
Bank: 1 Reg: 0x0c30109c Val: 0x00000000 -> drive_gpio_dis3
Bank: 1 Reg: 0x0c3010a4 Val: 0x00000000 -> drive_gpio_dis4
Bank: 1 Reg: 0x0c3010ac Val: 0x00000000 -> drive_gpio_dis5
Bank: 0 Reg: 0x0243d004 Val: 0x00000000 -> drive_gpio_wan8
Bank: 0 Reg: 0x0243d00c Val: 0x00000000 -> drive_gpio_wan7
Bank: 0 Reg: 0x0243d014 Val: 0x00000000 -> drive_gpio_wan6
Bank: 0 Reg: 0x0243d01c Val: 0x00000000 -> drive_gpio_wan5
Bank: 0 Reg: 0x0243d024 Val: 0x00606000 -> drive_uart2_tx
Bank: 0 Reg: 0x0243d02c Val: 0x00606000 -> drive_uart2_rx
Bank: 0 Reg: 0x0243d034 Val: 0x00606000 -> drive_uart2_rts
Bank: 0 Reg: 0x0243d03c Val: 0x00606000 -> drive_uart2_cts
Bank: 0 Reg: 0x0243d044 Val: 0x00000000 -> drive_uart5_rx
Bank: 0 Reg: 0x0243d04c Val: 0x00000000 -> drive_uart5_tx
Bank: 0 Reg: 0x0243d054 Val: 0x00000000 -> drive_uart5_rts
Bank: 0 Reg: 0x0243d05c Val: 0x00000000 -> drive_uart5_cts
Bank: 0 Reg: 0x0243d064 Val: 0x00000000 -> drive_gpio_mdm1
Bank: 0 Reg: 0x0243d06c Val: 0x00000000 -> drive_gpio_mdm2
Bank: 0 Reg: 0x0243d074 Val: 0x00000000 -> drive_gpio_mdm3
Bank: 0 Reg: 0x0243d07c Val: 0x00000000 -> drive_gpio_mdm4
Bank: 0 Reg: 0x0243d084 Val: 0x00000000 -> drive_gpio_mdm5
Bank: 0 Reg: 0x0243d08c Val: 0x00000000 -> drive_gpio_mdm6
Bank: 0 Reg: 0x0243d094 Val: 0x00000000 -> drive_gpio_mdm7
Bank: 0 Reg: 0x0243d09c Val: 0x00000000 -> drive_bcpu_pwr_req
Bank: 0 Reg: 0x0243d0a4 Val: 0x00000000 -> drive_mcpu_pwr_req
Bank: 0 Reg: 0x0243d0ac Val: 0x00000000 -> drive_gpu_pwr_req
Bank: 0 Reg: 0x0243d0b4 Val: 0x0001f000 -> drive_gen7_i2c_scl
Bank: 0 Reg: 0x0243d0bc Val: 0x0001f000 -> drive_gen7_i2c_sda
Bank: 0 Reg: 0x0243d0c4 Val: 0x0001f000 -> drive_gen9_i2c_sda
Bank: 0 Reg: 0x0243d0cc Val: 0x0001f000 -> drive_gen9_i2c_scl
Bank: 0 Reg: 0x0243d0d4 Val: 0x00000000 -> drive_usb_vbus_en0
Bank: 0 Reg: 0x0243d0dc Val: 0x00000000 -> drive_usb_vbus_en1
Bank: 0 Reg: 0x0243d0e4 Val: 0x00000000 -> drive_gp_pwm7
Bank: 0 Reg: 0x0243d0ec Val: 0x00000000 -> drive_gp_pwm6
Bank: 0 Reg: 0x02441004 Val: 0x0a00a000 -> drive_ufs0_rst
Bank: 0 Reg: 0x0244100c Val: 0x0a00a000 -> drive_ufs0_ref_clk
Hi walterkim,
Looks like your pinmux setting needs modification.
In MB1 CFG file tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
pinmux.0x0c3010a8 = 0x00000411; # gpio_dis5_pu5: gp, tristate-enable, input-disable
Please make this as
pinmux.0x0c3010a8 = 0x00000401; # gpio_dis5_pu5: gp, tristate-disable, input-disable
Thank you WayneWWW
LCD1_BKLT_PWM is good.
pinmux…
Hai Walterkim,
   I want to use PWM on my carrier board, so please suggest which pin is compatiable for PWM.
Thanks in advance.
Regards,
Surendra Allam.
Hai Walterkim,
Thanks in advance.
Regards,
Surendra Allam.
Hi
We would like to use GP_PWM1 on Pin GPIO3_PU.00 (B27) for a SPEAKER. When we measure the Output of the PWM, we see that the frequency is always 72 kHz. Writing other values to /sys/class/pwmchip0/pwm0/period do not change the frequency. When writing into the duty_cycle, we see that the output signal changes accordingly. Are we missing something?
