In the cuda manual, attomic add can be implmented using compare and swap like this:
device double atomicAdd(double* address, double val)
unsigned long long int* address_as_ull =
(unsigned long long int*)address;
unsigned long long int old = *address_as_ull, assumed;
do {
assumed = old;
old = atomicCAS(address_as_ull, assumed,
__double_as_longlong(val +
__longlong_as_double(assumed)));
} while (assumed != old);
return __longlong_as_double(old);
So I tried to implement atomic add in Opencl like this:
double atomicDoubleAdd(__global double* address, double val)
ulong * address_as_ull =(ulong *)address;
ulong old = *address_as_ull, assumed;
do {
assumed = old;
old = atom_cmpxchg(address_as_ull, assumed,as_ulong(val +as_double(assumed)));
return as_double(old);
however, it fails when I tried to build the program, so if anybody knows how to do this?
