Can i download pytorch 1.9 with jetpack 6.2.1 in jetson orin nano?
i have jetson orin nano with jetpack 6.2.1.
i want to install pytorch 1.9.0 in it with python 3.9 or lower.
can build it from the source github ?
To install PyTorch 1.9 on your Jetson Orin Nano with JetPack 6.2.1, you have a few options. Before we dive into the installation process, let’s ensure your device meets the necessary requirements.
Hardware Requirements:
Your Jetson Orin Nano should have a minimum of 8GB of memory and a 128GB (or larger) NVMe drive. Additionally, you’ll need a USB-C flashing cable, a monitor, keyboard, and mouse for the setup process.
Software Requirements:
You’ve mentioned that you’re running JetPack 6.2.1, which is compatible with PyTorch 1.9. You’ll also need to ensure you have the necessary dependencies installed.
Installing PyTorch 1.9:
There are two primary methods to install PyTorch 1.9 on your Jetson Orin Nano:
  1. Pre-built Wheels:
    You can try installing PyTorch using pre-built wheels, which are available for Jetson devices. This method is quicker and more straightforward. You can use the following command:
pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v46/pytorch pytorch==1.9.0+cu11.4
This command installs PyTorch 1.9 with CUDA 11.4 support.
  1. Building from Source:
    If you prefer to build PyTorch from source, you can follow these steps:
# Install dependencies
sudo apt-get update
sudo apt-get install -y libopenblas-base libopenmpi-dev libomp-dev
# Clone the PyTorch repository
git clone --recursive https://github.com/pytorch/pytorch.git
# Checkout the PyTorch 1.9 branch
cd pytorch
git checkout v1.9.0
# Build PyTorch
python setup.py install
This process will take longer, as it builds PyTorch from source.
Comparison of Methods:
Both methods have their advantages. The pre-built wheel method is faster and more convenient, while building from source provides more control over the installation process.
Additional Tips:
  • Ensure you have the necessary dependencies installed before installing PyTorch.
  • If you encounter issues during the installation process, you can try cleaning the build directory and restarting the installation process.
  • You can verify the PyTorch installation by running a simple test script, such as:
import torch
print(torch.__version__)
This should output the PyTorch version you just installed.
In summary, you can install PyTorch 1.9 on your Jetson Orin Nano with JetPack 6.2.1 using either pre-built wheels or by building from source. Both methods have their advantages, and you can choose the one that best suits your needs.
On JetPack 6.2.1, it by default uses Python 3.10 and PyTorch 2.6+.
But you can build it from the source manually.
The detailed steps are already shared in the comment above.
Hi
can i download Python 3.9 or lower and build it from the source manually ?
or i switch to JetPack 5.4.4
thanks
You can give it a try.
We have users that upgrades to the custom Python 3.12.
So the downgrade should work but you might need to handle some compatibility issue manually.
