When displaying an image using deepstreamsdk (using nvbuffercomposite) as in the image below,
Can I draw a separate UI for each video?
If you can draw a UI, what is the way (qt, x11, etc…)?
Thank you.
Thank you.
To access single video - User should use demuxer component for each source and use required UI framework as needed by them
I can see this in samples applications?
thank you.
