Can I extract SEI from l_frame.data
• Hardware Platform Jetson
• DeepStream Version 6.3
• JetPack Version 5.1.2
• TensorRT Version
I find below code inside deepstream_test_3.py. And I want to know can I extract SEI data from this l_frame.data? If not, how can I get the h264 frame data?
def pgie_src_pad_buffer_probe(pad,info,u_data):
frame_number=0
num_rects=0
got_fps = False
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
data = l_frame.data
SEI is the header information inside the H264 raw data. H.264 : Advanced video coding for generic audiovisual services (itu.int)
You need to get it from the h264 ES stream.
I think this topic is duplicated with How to get the SEI payload in Deepstream pipeline - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums.
