Can I get GPU's profile of Tensorflow's mnist by Nvidia Visual profiler?
Hello
I just started study Deep Learning ,and I try to use various DL-Frameworks.
I use Ubunt14.04 , CUDA7.5 and Maxwell TIYUN X.
I could get GPU’s profiles of both the Chainer and Caffe by using Nvidia Visual Profiler.
Now I try to get GPU’s profile of Tensorflwos’ mnist. But I got some erros.
I’d really appreicaite it if anyone tell the way to solve this issue.
1.I installed Tensorflow by “pip install” and I confirmed correct operation of Tensorflow’s mnist.
2.I tried to get GPU’s profile , “convolutional.py” it is minist code of Tensorflow.
But Visual profiler sjow alot of errors as below.
https://www.dropbox.com/s/2eo5jgn5uk93pxg/TensorflowProfFirstError.jpg?dl=0
3.So I found nice URL
http://austindw.com/blog/programming/profiling-cuda-through-python-with-nvvp
4.Hence I add !/use/bin/env python at the begin of python code and did chmod +X convolutional.py.
5.I retry to get GPU’s profile of Tensorflow’s mnist.
6.But I got Importred Error:numpy as below.
https://www.dropbox.com/s/88smp83exfs9g6m/Tensorflow_import_numpy_error.jpg?dl=0
7.I did python >>> import numpy ,but I did not get no-errors as blow.
https://www.dropbox.com/s/ncknqojtdqn9xp4/importnumpy.jpg?dl=0
8.I can not the reason why the import numpty error did in Visual profiler.
Please teach me the way to get GPU’s profile of Tensorflow’s mnist.
Hi,yoshimartina
I profile the convolutional.py at my desktop, it works OK. Timeline generated.
please make sure you can run below command directly to make sure the env is OK
$ python convolutional.py
Then if you want to profile using nvvp, you can select /usr/bin/python as the binary and the script as the argument.
This works for me.
Please have a try.
Thank you fpr your reply ,verai
I checheck $pyhon convolutiona.py
It was OK, but I could not get good result.
I guessed taht it was Python minor error, and uninstall python and tensorflow,and re-install them again.
So I could get Trnsorflow’s profile.
Thank you for your advice.
Regards,
