If I have a text with emotion ,I am using Google text to speech . Then from this synthesised speech can the auto emotion feature of audio2face determine the exact emotion in the speech and make the agent speak with that emotion.Also can we use text as Input to audio2face,can auto emotion determine emotion from text and make the agent speak with that emotion. Please answer this questions.
Hello and welcome to the forums @RS7
You can use the streaming player and stream from arbitrary sources. Please take a look at this Riva tutorial.
Regarding emotion from text, I’m not sure if there’s a reliable way of doing it as the same text can be said with different emotions. Audio2Face uses audio to automatically create emotions and if the audio doesn’t have emotions, then probably A2F won’t produce expected results.
Thank you for the response.Does riva text to speech synthesis ,synthesis speech with emotions based on the emotion in the text?Also I am talking about the auto emotion features of A2F . What I understood about the auto emotion feature is that it automatically identifies the emotion in the speech and makes the agent express it using A2F.
