Can I install a supercap charging circuit on a custom board to replace a coin battery?
Thank you.
That’s ok.
If I want to maintain rtc using the supercap added to the carrier board like this, which one of /dev/rtc* should I read?
manager@ubuntu:~$ sudo hwclock -r
[sudo] password for manager:
1970-01-01 09:01:41.214855+09:00
manager@ubuntu:~$ sudo hwclock -r -f /dev/rtc1
1970-01-01 09:01:51.222914+09:00
manager@ubuntu:~$ sudo hwclock -r -f /dev/rtc0
1970-01-01 09:01:54.581129+09:00
manager@ubuntu:~$ timedatectl
               Local time: Thu 1970-01-01 09:02:04 KST
           Universal time: Thu 1970-01-01 00:02:04 UTC
                 RTC time: Thu 1970-01-01 00:02:04
                Time zone: Asia/Seoul (KST, +0900)
System clock synchronized: no
              NTP service: active
          RTC in local TZ: no
manager@ubuntu:~$ ll /dev/rtc*
lrwxrwxrwx 1 root root      4 Mar 28  2023 /dev/rtc -> rtc1
crw------- 1 root root 249, 0 Mar 28  2023 /dev/rtc0
crw------- 1 root root 249, 1 Mar 28  2023 /dev/rtc1
Thank you.
It should be rtc0.
In r35.x.x versions, do I need to change the kernel image by modifying CONFIG_RTC_HCTOSYS_DEVICE? In r36.3 version, do I not need to modify it?
