Can I join/merge two objects as one(both under the same X-form) in Omniverse Create?
Hi @yuanmiaomiao1994! Depends on what you’re wanting to do.
- You could simply select them and group them under a new Xform with Crtl+G. You’ll still have separate mesh prims, but you can move the group xform to move them together.
- You could use the Merge Mesh Tool.
- Enable the extension from the Extensions Manager. Window - > Extensions. The extension details explains how to use it.
- Open the tool window. Window → Merge Meshes
