I have two of my external displays put vertically next to each other. I would like them to be treated as one monitor/screen so that when I maximize a window, it would go over both of them. This is something that should be possible: [SOLVED] Treat two monitors as one? / Kernel & Hardware / Arch Linux Forums but nvidia drivers do not seem to support xrandr --addmode
In theory, that should be a use-case for xrandr --setmonitor, i.e. randr 1.5 monitor objects, and at least gnome should honor that. I had no success when playing with that some time ago, though. Alternatives might be fakexrandr or fakexinerama.
i.e. tell compiz not to detect displays. But it seems now my monitors go blank every 15 seconds, hm!
Anyway, the script for my monitors seems to be:
#!/bin/bash
state=gsettings get org.compiz.core:/org/compiz/profiles/unity/plugins/core/ detect-outputs
if [ $state = “true” ]
then
gsettings set org.compiz.core:/org/compiz/profiles/unity/plugins/core/ detect-outputs false
gsettings set org.compiz.core:/org/compiz/profiles/unity/plugins/core/ outputs “[‘2560x1440+0+0’, ‘2880x2560+2560+0’]”
else
gsettings set org.compiz.core:/org/compiz/profiles/unity/plugins/core/ detect-outputs true
fi
(since when I remove the laptop from the dock, I need Compiz to start detecting those monitors otherwise it still thinks I have three external ones)
addmode is just refused if the output (the monitor) does not support that mode.
The VIRTUAL1 output is a special feature of the old “intel” driver, no other driver supports that.
