Can i modify RTL8211F-CG's register in some driver
Hi
I want to close CLKOUT pin’s output of RTL8211F-CG, using mdio-tools is OK, now i
want to intergrate this into RTL8211F-CG’s driver.
Is there any RTL8211F-CG driver i can put this into and how can it be probed?
thanks
the carrier boad is similar to P3701 but using ethernet@2310000 connecting a RTL8211F-CG as phy. the ethernet works well, but no phy’s driver be loaded.
Please check with Realtek if they have a dedicated PHY driver for this.
thanks, i just want to check whether or which phy driver has be loaded. Now the problem has be solved. I add one line item to device-tree:
realtek,clkout-disable
