Can I monitor a common block?
hi,
I am pretty new to both Fortran and pgdbg. Currently I am working on a big Fortran program, which have several named common blocks. When I print or type of a named common block, it says NO TYPE for the common block. Would it be possible to do it with pgdbg?
Hi L Huang,
You should be able to use the print command to view the contents of a common block (See Section 1.10.5 http://www.pgroup.com/doc/pgitools.pdf), so I’m not sure why your getting this error. Are you able to print out the common block’s elements? Is your common block named?
  • Mat
Thanks for your reply.
I am actually looking at named common blocks. And I can print the member variables of a common block, but not the common block by print the_name_of_common_block.
L Huang
Hi L Huang,
I’m not sure since it should work. Unfortunatley our office is closed this week so it will be next wek before I can ask our Tools group.
Sorry for the delay,
Mat
