I am working on receiving data from a sensor and I want to read this data through a timer interrupt, I have read the Nvidia TRM in section 8 of Timers, however, I don’t know if it is possible to do this with python.
Do you mean this document?
8.1.2.5 Timers
The Cortex-R5 does not have any integrated timers. Timers for the AON Cluster are provided by a separate timer block in the AON Cluster.
Since the document says there is no timer in Cortex-R5, would you mind telling us that which function you want to use?
Do you want to get the system time with Python?
Hi AastaLLL,
Thanks for your answering.
What I want to do is set up a timer interrupt on the Jetson Xavier. I am new to this and have read about the registers in section 8.4.4. However, as I understand it, manipulating these registers directly might not be feasible. What I am looking for is a way to configure these registers using Python for a specific application I am developing on the Xavier.
Thanks for the expansion.
Please find below the topic for more info:
If the PWM works for your use case, there is a Python-based library for it.
