• Hardware Platform (Jetson / GPU) GPU • DeepStream Version 7.0.0 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) 538.18 • Issue Type( questions, new requirements, bugs) questions
I have a python pipeline that I run on t4 server. It takes as input a video file and extracts frames from it and uses a couple of deep learning models and then it sets up a folder system and runs a photogrammetry software called colmap to do a 3d reconstruction of the object from the images.
I wanted to run it in a deepstream SDK. Is it possible to run the COLMAP in deepstream SDK?
@Fiona.Chen Thanks for your reply. I’m new to Deep stream SDK, could you provide some reference document to help me get started with running Colmap in Deepstream?
