GPIO3_PP.06 have to pull up external. Can I set the io-high-voltage to disable by setting the register?
It has been pulled up to 3.3V, so the 3.3V Tolerance should be enabled.
I know it has been pulled up to 3.3V,but I use the custom carry board and forget to external pull up. Can I disable 3.3V Tolerance by setting the register not modify the device tree.
Please set the pinmux sheet and generate dts files for that.
