Can I set the TX2 board using WIFI?
HI
My host pc is connected to the internet by wifi.
and host pc is connected to TX board by LAN line.
I choose “Device accesses Internet via host machine through setting up a new DHCP server ~ on host”
During the installation process, I received the following message:
Unable to determine IP Address of Jetson
It gives me 2 options:
  1. Try again
  2. Enter it manually
Coul you please answer it?
Hi maglc13,
So you would like to setup the ethernet of jetson through your host?
Does it also work well with other platform (e.g your laptop or anything else)?
Hi maglc13,
Have you completed the installation with JetPack? Or it’s still an issue to support?
Hello
I completed the installation with JetPack.
