1.Can I specify ACPI (Advanced Color Plane Interpolation) for ISP demosaicing?
2.How can I specify parameters when possible?
3.And what is the default interpolation method?
4.If demosaicing with ACPI is executed outside the ISP, please tell me where it will be processed.
Notice
I do not have permission to refer bin files and documents yet in DevZone.
I refer your answer link.
I referred to the entire document,but all my questions are unresolved.
Since I want to know what concrete interpolation method is, I continue with the four questions.
I corrected the contents of questions 2,3 and 4.
I want an answer as soon as possible. I hope that you will answer even one of them.
However, I would like you to finally answer everything.
2.What is the default interpolation method? (Refer Notice)
3.How can I specify demosaicing method when possible?
Is the block to be demosaiced a raw pipeline?
Notice
Quistion1–3 Examples of general interpolation methods :
Advanced Color Plane Interpolation(ACPI),
High Resolution Interpolation,
Fringe Tolerant Interpolation
Could you please see DriveWorks API part in DPX2? Thanks.
(/usr/local/driveworks-0.3/doc)
-> DriveWorks SDK Reference -> DriveWorks API -> RAW Pipeline -> dwDemosaicMethod.
I understand that the demosaic method can be selected by interpolation and downsampling.
What I want to know is whether you can specifically specify the interpolation method.
I would like to use ACPI.
Please read the previous two questions carefully.
