Hi I am using SD card A running with OS already in Jetson Nano It seems slow. I would like to use a new SD card B with new image on it to test if it is better. If I switch to SD card B and start initial startup then shutdown it would I be able still to boot from my older SD card A if I put it back again after ?
Is this duplicated with below topic?
Please just use one topic for same question.
