Can I use conda environment in Orbit?
I tried to use ORBIT today. However, I cannot run existing examples with an anaconda environment different from Isaac Sim. The conda environment which I tried on Orbit works well on Isaac Sim.
I changed launch.json and settings.json from .vscode on ORBIT.
// "python": "${workspaceFolder}/_isaac_sim/python.sh",
"python": "/home/bak/anaconda3/envs/isaac-sim/bin/python",
"envFile": "${workspaceFolder}/.vscode/.python.env",
"preLaunchTask": "setup_python_env"
[↑launch.json]
// Python environment path
// "python.defaultInterpreterPath": "${workspaceFolder}/_isaac_sim/kit/python/bin/python3",
"python.defaultInterpreterPath": "/home/bak/anaconda3/envs/isaac-sim/bin/python",
"python.envFile": "${workspaceFolder}/.vscode/.python.env",
[↑settings.json]
(bak is my HOME name)
I also tried to install pip packages like below refer to orbit.sh but it was insufficient to run the codes.
pip install pre-commit
pip install -e /home/bak/Projects/orbit/source/extensions/omni.isaac.orbit_envs[all]
Is there a way to run with conda environment?
@mayankmittal1410 please check this out
Thank you for bringing this up! The issue earlier was that even if inside a virtual environment, orbit.sh -p was only fetching the python from Isaac Sim.
We have updated the main branch with utilities to setup a conda environment safely and fix this issue. This happened on this MR.
Please open a GitHub issue if the issue still persists.
