Here is my log, I guess that my t1200 gpu doesn’t support ray tracing.
Error occurred during installation of View: Command failed: “C:\Users\hanrui\AppData\Local\ov\pkg\view-2021.3.9\omni.view.warmup.bat”
2021-12-16 07:00:16 [3,636ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
- The driver is not installed properly and requires a clean re-install.
- Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
- The driver cannot enumerate any GPU: driver, display or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
2021-12-16 07:00:20 [7,361ms] [Error] [omni.kit.window.viewport.plugin] Failed to initialize resource manager
2021-12-16 07:00:20 [7,361ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
2021-12-16 07:00:20 [7,361ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required plugins
2021-12-16 07:00:20 [7,402ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘get_mouse_event_stream’
At:
c:\users\hanrui\appdata\local\ov\pkg\view-2021.3.9\kit\extscore\omni.kit.window.viewport\omni\kit\viewport\scripts\context_menu.py(27): on_startup
c:/users/hanrui/appdata/local/ov/pkg/view-2021.3.9/kit/plugins/bindings-python\omni\ext\impl_internal.py(143): _startup_ext
c:/users/hanrui/appdata/local/ov/pkg/view-2021.3.9/kit/plugins/bindings-python\omni\ext\impl_internal.py(174): startup_all_extensions_in_module
c:/users/hanrui/appdata/local/ov/pkg/view-2021.3.9/kit/plugins/bindings-python\omni\ext\impl_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2):
2021-12-16 07:00:20 [7,402ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] Failed to process python module extension in ‘c:/users/hanrui/appdata/local/ov/pkg/view-2021.3.9/kit/extscore/omni.kit.window.viewport/.’.
ERROR: Could not find a version that satisfies the requirement numpy==1.19.0 (from versions: none)
ERROR: No matching distribution found for numpy==1.19.0
2021-12-16 07:00:48 [35,976ms] [Error] [carb.crashreporter-breakpad.plugin] failed to upload minidump: file:‘C:/Users/hanrui/AppData/Local/ov/data/Kit/View/2021.3/366a3bcf-97d7-43cd-936f-a578a1005419.dmp’ code:0 response:
2021-12-16 07:00:56 [43,985ms] [Error] [carb.crashreporter-breakpad.plugin] failed to upload minidump: file:‘C:/Users/hanrui/AppData/Local/ov/data/Kit/View/2021.3\6909c944-b8b3-4a2c-8dd2-12048bc68953.dmp’ code:0 response:
2021-12-16 07:00:57 [44,419ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.view.compass.plugin.dll!+0x3500
2021-12-16 07:00:57 [44,419ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginRegisterEx
2021-12-16 07:00:57 [44,419ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginStartup
2021-12-16 07:00:57 [44,420ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.app.plugin.dll!+0x10f23
2021-12-16 07:00:57 [44,420ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.app.plugin.dll!+0xb4d1
2021-12-16 07:00:57 [44,422ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x21ef
2021-12-16 07:00:57 [44,422ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x2c64
2021-12-16 07:00:57 [44,422ms] [Fatal] [carb.crashreporter-breakpad.plugin] KERNEL32.DLL!BaseThreadInitThunk
2021-12-16 07:00:57 [44,422ms] [Fatal] [carb.crashreporter-breakpad.plugin] ntdll.dll!RtlUserThreadStart
