Issue Description: Whether HOST PC with system requirements mentioned in documentation is mandatory or can i work only using Amazon VEW EC2 instance alone .
example : i can cross compile and through SCP can i copy the binaries to the drive AGX thor?
or any mandatory steps need to be performed only using host PC
Dear @nandhini.ravikumar ,
You need host PC with ubuntu 24.04 to flash DRIVE OS.
Flashing does not work using WSL. If the requirement is just to download the docker and cross compile applications, you can use WSL.
To better understand the requirement: could you please explain why a native Ubuntu 24.04 host PC is mandatory for flashing DRIVE OS, and which parts of the workflow specifically do not work under WSL/VEW instance?
I also like to understand whether the host PC is required only for flashing, or also for development tasks such as building Docker containers, cross-compiling, and running local inference/testing before deployment to DRIVE AGX Thor.
If possible, could you share the key technical dependency or limitation that makes WSL unsupported for flashing? This would help us align our setup with the recommended workflow.
Whether drive AGX Thor Hardware i received will have pre flashed OS image or the initial set up need to be done by us?
Thanks for your reply, to understand correctly ,i would like to check with you on 2 scenarios
Bare-metal provisioning, Major version upgrades, or recovery from stall state - Drive OS flasing is needed and we need host PC
For Field updates, application deployment, and OTA (Over-The-Air) testing separate USB 3.0 can can be used . Host PC is not needed
Already the devkit have DOS 7.0.3 , if i want to create a new application, cross compile and generate binary and to run the application in Thor HW, do i need Host PC or only virtual environment is fine .
