I may buy one of below
A. Jetson Xavier NX Developer Kit
B. Jetson TX2 Developer Kit
In course ‘Getting Started with AI on Jetson Nano’, could I get the project codes to run on ‘Jetson Xavier NX Developer Kit’ or ‘Jetson TX2 Developer Kit’?
Or where can I get the project codes?
Or how can I get the similar SD card images for ‘Jetson Xavier NX Developer Kit’ or ‘Jetson TX2 Developer Kit’?
Unless you already have some projects based on TX2 I would prefer the Xavier NX as this is much more powerful than the TX2.
The “Hello AI world” tutorial are based on Jetson-Inference which is compatible with Jetson Nano/TX1TX2 and Xavier AGX/NX.
Follow the “Getting started - Documentation” section for your Jetson/Xavier model here, there are links to the SD card images and instructions how to install:
Xavier NX has two MIPI CSR port where you can connect compatible cameras (RPI camera via ribbon cable). There are some carrier boards available that feature more than two MIPI CSR ports, look at Jetson Partner Products page.
I have successfully used webcams over network RTSP stream (Wifi or Ethernet) on my Xavier. You should also be able to use USB cameras (didn’t try it myself).
