I’m trying to parallelize my sequencial C code and offload to NVIDIA GPU with OpenACC(PGI compiler)
My code is written as a sequencial code. And calling very long functions frequently, like below.
int main()
// blah blah...
for(i=0; i<10; i++)
for(j=0; j<20; j++)
big_function(a,b,c);
// blah blah...
int big_function(a,b,c)
small_function_1(a);
small_function_2_with_data_dependencies(b);
That kind of case case, big_function() can parallelize and run on GPU?
I declared whole of for loop to parallized region using #pragma acc kernels . like below.
#pragma acc routine
int big_function(int a, int b, int c);
#pragma acc routine
int small_function_1(int a);
#pragma acc routine
int small_function_2_with_data_dependencies(int b);
int main()
// blah blah...
#pragma acc data ~~~~
#pragma acc kernels
for(i=0; i<10; i++)
for(j=0; j<20; j++)
// blah blah...
But the compiled file takes very long time to finish. And the result was not correct.
Can I use OpenACC to parallelize sequecial code which using many function calls?
Or Do I have to break and divide big_function() to small parts?
I’m using
Ubuntu 14.04 LTS
PGI 15.7
CUDA 6.5
NVIDIA GeForce 960GTX (Maxwell architecture)
