can I use pinned memory?
Hi All,
I have installed CUDA 2.3 driver , toolkit and SDK and i want to use pinned memory but when I see the cudaDeviceProp structure then one of its member value is
canMapHostMemory 1 .
I want to know what this value indicates?
I think it indicates this property is on .
Hi ,
I have written code for using pinned memory :-
In my case :
dstSize = 17280000
      flag      = 2 ( cudaHostAllocMapped )
But after executing the line
I got error cudaErrorUnknown .
can any one help on this ?
I have seen SDK 2.3 project simpleZeroCopy code and I try to implement it in my code. But I have some confusion on using it.
Is following code should be only on main function or I can write it in any function :
Because if I write it on main function then it works fine but if I write it any other function then it gives error. Please help…
This problem is solved . We can write it any function . Actually I got this error because of prior error.
And what was your error?
I got also a “cudaErrorUnknown” when I try to allocate pinned memory with cudaHostAlloc().
Make sure you’re first calling:
cudaSetDeviceFlags(cudaDeviceMapHost);
