Can I use Quadro K4000 and K2000 for GPUDirect v2 Peer-to-peer (P2P) communication?
I use:
- Single CPU (Intel Core i7-4820K Ivy Bridge-E) 40 Lanes of PCIe 3.0 + MotherBoard MSI X79A-GD65 (8D)
- WindowsServer 2012, MSVS 2012 + CUDA 5.5 and compiled as 64-bit application
- GPUs nVidia Quadro K4000 and K2000
- All Quadros in TCC-mode (Tesla Compute Cluster)
- nVidia Video Driver 332.50
- Switch off VT-d in BIOS
simpleP2P-test shown that, all Quadros K4000 and K4000 - IS capable of Peer-to-Peer (P2P), but Peer-to-Peer (P2P) access - Quadro K4000 (GPU0) <-> Quadro K2000 (GPU1) : No.
[C:\ProgramData\NVIDIA Corporation\CUDA Samples\v5.5
[C:\ProgramData\NVIDIA Corporation\CUDA Samples\v5.5\0_Simple\simpleP2P…/…/bi n/win64/Release/simpleP2P.exe] - Starting… Checking for multiple GPUs… CUDA-capable device count: 3
GPU0 = " Quadro K4000" IS capable of Peer-to-Peer (P2P)
GPU1 = " Quadro K2000" IS capable of Peer-to-Peer (P2P)
GPU2 = " GeForce GT 640" NOT capable of Peer-to-Peer (P2P)
Checking GPU(s) for support of peer to peer memory access…
Peer-to-Peer (P2P) access from Quadro K4000 (GPU0) → Quadro K2000 (GPU1) : No
Peer-to-Peer (P2P) access from Quadro K2000 (GPU1) → Quadro K4000 (GPU0) : No
Two or more SM 2.0 class GPUs are required for C:\ProgramData\NVIDIA Corporation \CUDA Samples\v5.5\0_Simple\simpleP2P…/…/bin/win64/Release/simpleP2P.exe to r un. Support for UVA requires a GPU with SM 2.0 capabilities. Peer to Peer access is not available between GPU0 <-> GPU1, waiving test.
_Simple\simpleP2P../../bi n/win64/Release/simpleP2P.exe] - Starting... Checking for multiple GPUs... CUDA-capable device count: 3
Checking GPU(s) for support of peer to peer memory access...
Peer-to-Peer (P2P) access from Quadro K4000 (GPU0) -> Quadro K2000 (GPU1) : No
Peer-to-Peer (P2P) access from Quadro K2000 (GPU1) -> Quadro K4000 (GPU0) : No
_Simple\simpleP2P../../bin/win64/Release/simpleP2P.exe to r un. Support for UVA requires a GPU with SM 2.0 capabilities. Peer to Peer access is not available between GPU0 <-> GPU1, waiving test.
Quadros in TCC-mode:
nvidia-smi.exe"
Tue Mar 11 12:43:05 2014
| NVIDIA-SMI 5.320.57 Driver Version: 320.57 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| 0 Quadro K2000 TCC | 0000:01:00.0 Off | N/A |
| 30% 30C P8 N/A / N/A | 6MB / 2047MB | 0% Default |
| 1 GeForce GT 640 WDDM | 0000:02:00.0 N/A | N/A |
| 40% 32C N/A N/A / N/A | 2016MB / 2047MB | N/A Default |
| 2 Quadro K4000 TCC | 0000:03:00.0 Off | N/A |
| 30% 36C P8 10W / 87W | 8MB / 3071MB | 0% Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 1 Not Supported |
In the documentation said that: https://developer.nvidia.com/gpudirect
“GPUDirect eliminates unnecessary system memory copies, dramatically lowers CPU overhead, and reduces latency, resulting in significant performance improvements in data transfer times for applications running on NVIDIA Tesla™ and Quadro™ products.”
More detailed specifications of Quadros there, but there are only about GPUDirect For Video, and nothing about P2P: http://www.nvidia.com/content/PDF/line_card/6660-nv-prographicssolutions-linecard-july13-final-lr.pdf
About PCIe bus:
nvidia-smi -q
GPU 0000:01:00.0
Product Name : Quadro K2000
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Device Id : 0x0FFE10DE
Bus Id : 0000:01:00.0
Sub System Id : 0x094C10DE
GPU Link Info
PCIe Generation
Max : 2
Current : 1
Link Width
Max : 16x
Current : 8x
FB Memory Usage
Total : 2047 MiB
Used : 6 MiB
Free : 2041 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Compute Mode : Default
GPU 0000:02:00.0
Product Name : GeForce GT 640
PCI
Bus : 0x02
Device : 0x00
Domain : 0x0000
Device Id : 0x0FC110DE
Bus Id : 0000:02:00.0
Sub System Id : 0x8A921462
GPU Link Info
PCIe Generation
Max : N/A
Current : N/A
Link Width
Max : N/A
Current : N/A
GPU 0000:03:00.0
Product Name : Quadro K4000
PCI
Bus : 0x03
Device : 0x00
Domain : 0x0000
Device Id : 0x11FA10DE
Bus Id : 0000:03:00.0
Sub System Id : 0x097C10DE
GPU Link Info
PCIe Generation
Max : 2
Current : 1
Link Width
Max : 16x
Current : 16x
FB Memory Usage
Total : 3071 MiB
Used : 8 MiB
Free : 3063 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Can I use GPUDirect v2 P2P with Quadros K2000/K4000, and if I can, then with which of these?
I use single CPU, so there should be one IOH with single PCIe-tree, isn’t it?
- I can't use P2P Direct Transfers - I transfered random generated data by using cudaMemcpy(gpu_ptr1, gpu_ptr0, cudaMemcpyDefault); successfully with 3 GB/sec on PCIe-gen2 8x (4 GB/sec theoretically), but function copies through the host - In VisualProfiler Context1(DtoH) and Context2(HtoD).
- I can't use P2P Direct Access by using __global__ Kernel(char *dst, char *src, size_t size) { int idx = blockIdx.x * blockDim.x + threadIdx.x; dst[idx] = src[idx]; } - I get an error when use function cudaDeviceEnablePeerAccess() and get 0 when using cudaDeviceCanAccessPeer()
