I read a document and found some parameters in state estimater module.
processNoiseVar4Loc
processNoiseVar4Size
processNoiseVar4Vel
measurementNoiseVar4Detector
noiseWeightVar4Loc
noiseWeightVar4Vel
And it looks that the document recommends that we should use “noseWeightVar4Loc” and “noiseWeightVar4Vel” for DeepSORT.
I would like to know what these are used for and do we have to use noiseWeightVar4Loc and noiseWeightVar4Vel instead of others (, more over can we use procesNoiseVar4Loc and so on with DeepSORT)?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
This is my device information below.
**• Hardware Platform (Jetson / GPU): jetson
**• DeepStream Version: 6.0
**• JetPack Version (valid for Jetson only): 4.6
**• Issue Type( questions, new requirements, bugs): questions
I’ve already read this section.
And I felt this section recommend me to use these settings blow instead of other configurations such as processNoiseVar4Loc and so on.
measurementNoiseVar4Tracker
Is there any problem to use ‘processNoiseVar4Loc’, ‘processNoiseVar4Size’, ‘processNoiseVar4Vel’ and ‘measurementNoiseVar4Detector’ with DeepSORT?
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
The reason why DeepSORT uses different params in Kalman filter than NvDCF is because we wanted to follow the same algo as in the original DeepSORT implementation. But, you are free to use the same Kalman filter params from NvDCF for DeepSORT.
