Can I use ssd for m.2 2230 with m.2 2280 slot on Jetson Orin devkit carrier board?
Do you have any recommended M.2 2230 NVMe SSD?
Thank you.
Do you mean Orin or Orin nano devkit? You can find the devkit carrier board spec in DLC. And then you can get the key type of slot of devkit carrier board and so you can get if your device can be used with. There is no other recommendation than the components in SCL.
