I downloaded the LPRnet from ngc via the cli but when I tried to use it to inference some images, it promted that -e -config something is required to specify. Does that means I have to train the model on my own dataset before inference?Also, what is the fomart for the Spec file metioned in the Document?
• DeepStream Version
• TensorRT Version
Hi kayccc, thanks for your response. Here is my driver version below:
NVIDIA-SMI 460.91.03 Driver Version: 460.91.03 CUDA Version: 11.2
I do not install DeepStream and TensorRT because I just try to use the pre-trained model to see if it can recognize my plates. Are they neccessary to be installed on my os in order to make inference?
Hi @user16037 ,
Could you take a look if the lprnet used in GitHub - NVIDIA-AI-IOT/deepstream_lpr_app: Sample app code for LPR deployment on DeepStream can be a reference for you?
