Can I use the SPI0_CS1 pin as a GPIO if I have MCP2515 connected and using SPI0 MISO MOSI SCK and CS0
I want to confirm if I can use the SPI0_CS1 on the 40-pin header on the Jetson Nano as a GPIO and toggle its state without any effect on the SPI0_CS0 using the device MCP2515.
Because I tried to do that and I got warnings in the dmesg from the MCP2515 driver, below I have attached the logs for reference.
[ 1193.158780] mcp251x spi0.0: GPIO lookup for consumer termination
[ 1193.158796] mcp251x spi0.0: using device tree for GPIO lookup
[ 1193.158810] of_get_named_gpiod_flags: can’t parse ‘termination-gpios’ property of node ‘/bus@0/spi@3210000/mcp2515@0[0]’
[ 1193.158829] of_get_named_gpiod_flags: can’t parse ‘termination-gpio’ property of node ‘/bus@0/spi@3210000/mcp2515@0[0]’
[ 1193.158838] mcp251x spi0.0: using lookup tables for GPIO lookup
[ 1193.158841] mcp251x spi0.0: No GPIO consumer termination found
[ 1193.159512] mcp251x spi0.0 can1: MCP2515 successfully initialized.
Hi trezen.parmar,
It seems you are using Orin Nano rather than Jetson Nano!?
Are you using the devkit or custom board for Orin Nano/Jetson Nano?
Do you want to use HW-based CS or SW-based CS for SPI0 interface?
I am using the Jetson orin nano devkit 8GB kit.
Jetpack version - 6.2.1
I am using HW based CS for SPI interface.
Okay, I have moved your topic to the correct category for Orin Nano.
Could you apply the patch from the following thread to check if it could help for your case?
Jetson orin nano SPI Speed not changing - #9 by KevinFFF
can you please explain me what the warnings are trying to convey,
can we ignore it?
will it cause any effect in the bus communication?
These warnings only mean the driver tried to find an optional GPIO for termination control, but no valid termination-gpios property was found in the device tree. Since the log ends with MCP2515 successfully initialized, the controller itself was still initialized correctly.
So yes, you can usually ignore these warnings if CAN communication works normally. By themselves they should not affect bus communication. They would only matter if your hardware design expects a GPIO-controlled termination resistor and that GPIO is missing or described incorrectly in the device tree.
Additionally, please reach out to your vendor regarding the MCP2515-specific issue.
I want to use this SPI0_CS1 pin as a GPIO. So, if I configure it as a GPIO, I want to make sure that the SPI0 peripheral with the MISO, MOSI, SCK, and CS0 will work unaffected.
Sure, since MCP2515 is connected and controlled by SPI0_CS0, you should be fine to configure SPI0_CS1 as GPIO for custom use case.
Please just remove spi@1 of the spi@3210000 node in device tree.
Thanks for your help on this.
